1976 7000 VIN codes
Old Feb 14, 2020 | 06:47 PM
kvnber4's Avatar
kvnber4
1976 7000 VIN codes
Can anyone decode this vin. R70BVX06847. This is a barn find. We think it is a 7000. Also if this is an 7000/F7000 can anyone tell me witch other model has the same doors. What is the difference between a 7000 and L7000? Also , we were told it has a 3208 Cat. I think it is a V175 (1145). Are these nearly the same?? I have tried the online decoders but they only do later 17 digit vin #,s. Thanks for your help.
Old Feb 14, 2020 | 07:03 PM
fordguy2100's Avatar
fordguy2100
When Numberdummy comes along he will potentially decode the vin (I don't see you actually post a vin tho? did you forget to type it?) and then he will inform you that you have posted in the light truck forum and you will get better help in the large truck forum. You can see if an admin/mod can move this post over to the correct sub forum or just start another thread over there
Old Feb 14, 2020 | 08:28 PM
Idaho Highboy's Avatar
Idaho Highboy
Veteran: Navy
https://www.ford-trucks.com/forums/vindecoder.php
https://www.vindecoderz.com/EN/Ford
...or Google and check for yourself with another website. Good luck
- IH
Old Feb 15, 2020 | 05:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by kvnber4
Can anyone decode this vin. (where is it?) This is a barn find. We think it is a 7000. Also if this is an 7000/F7000 can anyone tell me which other model has the same doors. What is the difference between a 7000 and L7000? Also , we were told it has a 3208 Cat. I think it is a V175 (1145). Are these nearly the same?? Thanks for your help.
7000 is an 700 w/a diesel engine. Post the VIN so we can see what you're working on.
Old Feb 15, 2020 | 08:53 AM
kvnber4's Avatar
kvnber4
That alone explains a lot. Thanks
tyedye
Feb 21, 2018 10:10 AM
leegbee
Apr 21, 2008 06:01 PM
meangenejr
Jan 4, 2006 06:24 PM
suzukijoe
1997 - 2003 F150
Jan 14, 2005 09:19 PM
xblazer01
1978 - 1996 Big Bronco
Feb 15, 2003 08:42 PM
