1990 E-150 Fuel Pump Relay location
Old Feb 14, 2020 | 12:03 PM
DentyMcDent's Avatar
DentyMcDent
1990 E150. I need to drain the gas tank as it's about 10 years old and I don't want to run that nasty gas through the engine.
I'm looking for the fuel pump relay so that I can run a jumper wire and pump the fuel out.
However, I can't find the fuel pump relay anywhere.
According to this: https://fusesdiagram.com/ford/fuses-...1992-1997.html it's supposed to be in the engine compartment near the "left-hand" inner fender. I'm not sure if that means driver's side, "left" when inside the car, or if they mean "left" when standing facing the engine. Just say drivers or passengers side! But I digress.
I've checked both inner fenders, and can't find anything remotely like a fuse box or panel. The closest thing is a little unlabeled box with two relays in it, and no identifiers of what they go to.
The driver's side interior fuse box just has fuses, no fuel pump relay that I can find.
Does anyone know where to point me?
Old Feb 14, 2020 | 05:22 PM
Hank85713's Avatar
Hank85713
FUEL PUMP RELAY
1990 Ford Truck E150 1/2 ton Van 5.0L MFI OHV 8cyl
The Fuel Pump Relayis located:
Under hood, driver side, front side of wheel well,mounted in relay block
Old Feb 14, 2020 | 06:07 PM
DentyMcDent
Thanks. I'm starting to think they relocated it, it's a handicapped conversion van, and they've done a lot of modifications.
I managed to just hook into the actual fuel pump itself and pump it all out that way.
docergo
Sep 28, 2024 09:21 AM
fattmann
30
Dec 29, 2018 01:50 PM
MYBOYDAVE
Sep 9, 2013 04:15 PM
Madmike33
1983 - 2012 Ranger & B-Series
Mar 29, 2007 12:17 PM
anthtony1967
Dec 27, 2006 04:33 PM
