Gearing! What gears ?! Help!
Old Feb 10, 2020 | 06:04 PM
Ian Clarke's Avatar
Ian Clarke
I’ve seen the chart... but what about the transmission your using or the motor your running? Doesn’t fit into the equation too?
Heres my setup: Engine-460,Trans-NP-435,
Tires-38.5x13.50. Stock NP-205 T-case
4.88’s or 4.56’s?
I know those 460’s like low rpm.
ALSOI have not bought tires yet.. so I can change that. Those are just the size I was planning on.
Old Feb 10, 2020 | 06:29 PM
john jamieson's Avatar
john jamieson
What do you use your truck for? Rock hopping? Hauling? Cruising? That will really determine what you want.
Old Feb 10, 2020 | 07:40 PM
00t444e's Avatar
00t444e
I would go with 4.88s.
Old Feb 10, 2020 | 08:23 PM
Ian Clarke's Avatar
Ian Clarke
90% on road 10% off road. And nothing heavy off road
Old Feb 10, 2020 | 08:24 PM
Ian Clarke's Avatar
Ian Clarke
that’s what I was thinking. Just don’t want be wrapped out at 55mph.
Old Feb 10, 2020 | 08:25 PM
00t444e's Avatar
00t444e
About 2600 RPM at 60 with 4.88 gears and 38.5" tires.
Old Feb 10, 2020 | 08:28 PM
Ian Clarke's Avatar
Ian Clarke
that should be good. Thank you!
Four.on.the.floor
Apr 14, 2015 10:40 AM
Madmaxz
Dec 17, 2011 08:09 PM
Fordtough300-6
Bronco II
Oct 7, 2004 11:51 PM
nissanjon
Feb 2, 2000 08:33 PM
