4.56 gears ?
Old Apr 7, 2015 | 12:59 PM
Four.on.the.floor's Avatar
Four.on.the.floor
4.56 gears ?
does anyone run 4.56 gears in there trucks. If you do I would like to know whats your final ratio and what size tires are you running and if you done a highway test what is your actual RPMs
Old Apr 7, 2015 | 01:54 PM
f100beatertruck's Avatar
f100beatertruck
Going from memory 4.56's are about 300rpm more than 4.10's, which are about 300rpm more than 3.55's at 60. So about 600 to maybe 700 rpms more at 60 than 3.55's
Old Apr 7, 2015 | 02:14 PM
85e150's Avatar
85e150
Excellent calculator here. You need to know actual diameters, and I think you should measure the loaded radius to really get the right diameter.
Novak Conversions - Gearing & Gearing Math for Jeeps
Old Apr 7, 2015 | 03:48 PM
CountryBumkin's Avatar
CountryBumkin
My truck came stock with 3:54 gears and 29" tires.
I now run 37" tires with 4:56 gearing and the rpm at highways speeds is about the same.
Old Apr 7, 2015 | 06:42 PM
Diesel_Brad's Avatar
Diesel_Brad
I hope you are at least running 35" tires for 4.56 gears
Old Apr 7, 2015 | 07:14 PM
animator's Avatar
animator
4.56 gears, locked, on 36" tires and it feels about the same as it was when I bought it (mostly stock, but on 32" tires)... granted, it hasn't been stock in over 10 years... but from what I remember, it's pretty close... Haven't had it on the highway recently enough to remember actual highway RPMs..
I am happy I went with these over 4.10 or 4.88...
Old Apr 14, 2015 | 10:40 AM
Four.on.the.floor
I want to build a truck that i will use mainly in the city at stoplights. and offroad to get to my fishing holes.
berky
Nov 2, 2012 11:57 AM
o_i_f_03_04
1997 - 2003 F150
13
Jul 25, 2008 10:41 PM
HIROLLN
Jan 8, 2004 09:43 AM
nissanjon
Feb 2, 2000 08:33 PM
