Sponsored by: Real Truck
Rear Rotor Grooves
Old Mar 28, 2020 | 04:45 PM
WWR's Avatar
WWR
Originally Posted by Bently_Coop
I had a similar issue when I had Hawk LTS pads and O'Reilly's rotors in the rear of my truck.
I switched to the Motorcraft BRS-757 and Centric High Carbon Rotor, haven't had an issue since.
I like the Hawk pads with cryo slotted rotors in front, however like TMT said they were not matched well with the O'Reilly's rotors.
This is one reason I tend to lean toward pad and rotor kits anymore. It's arguably superstitious but I choose to believe that someplace like PowerStop is going to (presumably, we hope) put together a combo that will play nice together. Doesn't have to be the drilled & slotted stuff most people think of when they hear PowerStop -- they offer basic OEM-design stuff, too
Oftentimes the kits are less expensive than piecing everything together, too, so that makes the decision that much easier
I enjoy reading TMT's posts and appreciate his willingness to share his knowledge.... although I fear in the long run I may not retain much of it and like most I just need something that fits, is easy to order/readily available, and works reasonably well. I'd love to be so knowledgeable on brakes and design but then I'd forget how to tie my shoes.
Old Mar 28, 2020 | 04:47 PM
TooManyToys.'s Avatar
TooManyToys.
Hawk LTS are a high metallic compound. They will eat a rotor that is not properly hardened, the cryogenic rotor measure a higher hardness the stock, but that loss in cold coefficient of friction is made up by the pads.
Old Mar 28, 2020 | 06:43 PM
Djosbun's Avatar
Djosbun
Nothing excites me more than posts by TooManyToys and Mark Kovalsky. There is nothing better than when an expert shares their intimate knowledge of super-detailed technical information.
-- Dave
Old Mar 28, 2020 | 09:57 PM
z31freakify's Avatar
z31freakify
Same thing happened to me with some ceramic brake pads, they made some deep grooves on my brand new rotors, threw those pos pads in the trash and installed organic compound brake pads and no more grooves, but the only down side is the brake dust, but I'm cool with it, less expensive to wash a vehicle than buing brakes.
Old Mar 28, 2020 | 10:01 PM
ford390gashog's Avatar
ford390gashog
Originally Posted by ncred02
May be time for a new shop.
So after only 1500 miles and keeping a close eye on the back brakes its starting to groove again. Slightly but its happening. I asked about the possibility of defective pads and got a pretty lame reply. Sucks because this guy has always been honest and works on every car (4) that I have. I'm tempted to go to the dealer and get some OEM pads and put them on myself
The grooves are definitely from the pads, if you go for Motorcraft pads get the Superduty severe use pads. Very rotor friendly and are the standard for fleet and heavy use.
Old Mar 30, 2020 | 09:55 AM
ncred02's Avatar
ncred02
I agree. The pads are the issue. I might give my guy one more crack at doing the right thing. If not I'll bring my business elsewhere.
Thanks for the help as always
Old Apr 17, 2020 | 12:01 PM
ncred02's Avatar
ncred02
So TMT what do you recommend. I think I'm going to do the rears myself. My "Go To" guy was a real disappointment. I just want them fixed.
On another note I did front shocks and a new steering stabilizer and what a difference. Not a Caddy but way better ride.
Old Apr 17, 2020 | 04:36 PM
TooManyToys.
I don't know what you have in the front, but the Motorcraft Super Duty version should be good for your 2015. That is past my years of service so no direct knowledge of that formulation.
Old Apr 18, 2020 | 10:46 AM
Djosbun's Avatar
Djosbun
If your mechanic blamed the grooves on carrying weight, you are doing the right thing by taking your future business elsewhere. He probably didn't expect the pads he installed to be so horrible (or maybe he had to go with a different pad due to availability) but his response to the grooving issue should have been different.
-- Dave
rb8484
Feb 5, 2020 12:20 PM
01__Excursion
Ford Truck Parts for Sale
Mar 6, 2018 05:39 AM
Cooter55
19
Dec 9, 2010 06:58 AM
Fordzilla80
17
Jun 6, 2009 05:03 PM
Alon@ModBargains
Apr 24, 2008 07:55 PM
