rear tank strap
Old Feb 10, 2020 | 04:23 PM
Sparty73's Avatar
Sparty73
rear tank strap
Quick question I removed and clean my old tank. I have new hoses and sending unit on board. I was able to get the tank up but the straps are difficult to reattached. I placed to newpadded material between tank and straps , and the tank seem to seat well. I can attach the straps on the front end , but on the back end there is a gap between the frame and strap. Im not sure if its the padding or what everything seems to line up and when I push the tank up there is next to no play on the front end , a little i can push up in the back . Any ideas.
Sean
Old Feb 10, 2020 | 04:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Floor jack and a block of wood.
Old Feb 10, 2020 | 05:39 PM
Sparty73's Avatar
Sparty73
I have no problem getting tank up, the back side of the strap i cant get close enough to thread. Maybe just need to be more forceful. Only thing i can think is the padding material isn't compressed enough and causing it to gap
S
Old Feb 10, 2020 | 07:19 PM
caravaggio2000's Avatar
caravaggio2000
I thought the same when putting mine in, but it went in further. Make sure the filler neck is positioned correctly and not getting hung up. I used two floor jack with wood. One to hold it in a good general spot and one to push up on the side I was working on. I got them just to the spot where I could thread the front and rear on both sides, then tightened them down. They pop into place there when you think you are almost done.
Old Feb 10, 2020 | 10:03 PM
John89's Avatar
John89
Check the upper straps. On the rear there is a groove/notch they ride in. On the front there is an adjustment nut. We had to play with ours a little to get our new tank just right .
Old Feb 17, 2020 | 08:40 AM
rchawaii's Avatar
rchawaii
Have to agree. When I redid mine, It wasnt meeting up either, until I pushed the tank closer toward the front of the truck. Then the strap positioned enough to get the bolt in.
Drunken_Chewbacca
May 8, 2018 03:31 PM
SteveH123
Aug 16, 2016 09:22 PM
evil_lincoln
Apr 28, 2011 01:13 PM
AndrewDahlin
Sep 18, 2010 10:43 AM
rjaywhit
Oct 7, 2009 09:03 AM
