Tire PSI
I have put my truck on a CAT scale to get weights.
Based on weights and inflation tables for my tires, 65psi in the front and 35psi when not towing. When towing, I go to 58psi.
I got 84000 miles on my last set of rear tires doing this.
My truck, for instance. I NEED 40psi front and 35psi rear to support the weight of the truck, passengers plus a 500ish lb safety margin. I don't go that low but I do run 48F and 42R which puts me well above what the tires are actually carrying and the ride is great. You absolutely do not need 80 and 70 just driving around unloaded.
Up to you to do the math and figure out what you actually need but I assure you, it's nowhere close to 80/70 unloaded.
At the door jamb sticker 90 PSI, it’s 3,450 lbs (6,900 total). Oddly enough, C&C F450’s with the same front axle have a 7,000 lbs front GAWR.... They might have different springs though. .
For the rear, GAWR is 9,900 lbs. The table says that at the sticker’s 80 PSI, each tire will support 3,000 lbs in dual mode (12,000 lbs total, 9,000 lbs with a single tire failure). At 70 PSI, it’s 2,720 per tire in a dual (10,880 total, but only 8,160 if one tire fails). Rear unloaded weight is probably around 4,000 lbs, so well below even the 70 PSI number.
Of note is the fact that you can’t get both axles to their GAWR without exceeding the GCVR.
70 PSI is the lowest number in the table, which is the minimum PSI per Continental. You could extrapolate weight capacity at sub-70 PSI levels, but that is likely not advisable.
Assuming an F250 4x4 CCSB, the max front GAWR is 5,200, with a base curb weight around 4,500 lbs (XL with no options probably). If you have the 275/70r18, minimum pressure would have to be 40 PSI to support 4,540 lbs. 50 PSI gets you to 5,360 lbs, which is over the GAWR with a 3% cushion.
If you door sticker says 50 and you take 10 off, you are down to the bare-bones minimum. A well optioned truck would probably be heavier in the front end, which would require 42, 43, or even 45 PSI to carry the load. That might be why you are seeing front pressures spike due to heat build up (under-inflated.)
REAR: Door jam calls for 80 psi and that is where it is at, but LOOK closes at the outer tread on both tires and both edges, note the dark black which is rubber that did not pick up the dust on the center tread. My guess is I can take off 10 psi bringing it down to 70 and get a full dust line across the contact patch
FRONT: Door jam calls for 90psui, I dropped it to 80, then 70psi and it looks great at that point. Full dust across the Contact patch.
70 psi all the way around on this '20 F 450 King Ranch as equipped...
YEP, dad taught me that when I got old enough to get on the old Ford 9n tractor and drive those ranch trucks. Charts, there weren't no stinkin charts, few folks had an air compressor and unless you have fixed a flat on a tractor tire, then pumped it up with a bicycle pump you don't know what a long day is.
If you had a gage, its was pencil gage and I defy you to get the same reading twice on the same tire.
On my Jeep TJ, with 37 x 12:50 x17 BFG KM2 I ran 16-18 psi to get a full contact patch, offroad I ran 3-5 psi...the chart does not give you all the answers.
