2000 Excursion V10 crank no start
Old Feb 8, 2020 | 10:17 AM
lblnsd's Avatar
lblnsd
I have a 2000 Excursion with a V10. It will crank fine but no start. There were no symptoms leading to the start failure. I have 34psi at the fuel rail and I have spark. I have swapped the cam sensor. There are no codes coming up. I have installed a new fuel pump and fuel filter. Any suggestions will be appreciated.
Old Feb 8, 2020 | 11:18 AM
1 Excursion camper's Avatar
1 Excursion camper
34 psi is an issue. Although it should start and idle with that pressure. You want at least 48 psi. I don't remember the spec offhand.
Old Feb 8, 2020 | 07:21 PM
2001F350dualwheel's Avatar
2001F350dualwheel
Fuel pressure regulator
Old Feb 9, 2020 | 08:20 AM
projectSHO89's Avatar
projectSHO89
It's not fuel pressure. The "spec", per the factory service manual, for KOEO is 35-45 psi (KEOR is 28-45 psi). 34 psi, while less than optimal and within the margin of testing error, is not going to cause a "crank, no fire" symptom at initial startup.
The FPR, if damaged internally, might be leaking fuel back into the vacuum line and causing a flooded condition. Disconnect the vacuum line and check for fuel in the line.
Is your PATS happy? If not, you will have your exact symptom indicated by a fast-flashing THEFT light at key-on.
Try shooting some flammable spray into the intake while cranking and see if you get some firing. If so, you have an issue with the injectors not firing (which is how PATS disables the engine).
Old Feb 9, 2020 | 10:28 AM
lblnsd's Avatar
lblnsd
I plan on replacing FPR since it is accessible now that I have IAC removed for cleaning. The theft light turns off after key is turned on. I have checked fuses related to PATS. I have tried spraying carb cleaner and it did not fire at all. I replaced crank position sensor. While doing this I noticed a possible Freon leak at the ac compressor. I cleaned and dried out the crank sensor connection. Thank you, Larry
Old Feb 9, 2020 | 11:25 AM
projectSHO89
If it won't fire on carb cleaner, then you have a problem with spark, timing, compression or air supply. It's not related to the fuel system, including PATS.
Follow the evidence, don't guess.
Old Feb 9, 2020 | 11:40 AM
lblnsd's Avatar
lblnsd
I have spark at the coil. I plan on replacing IAC(cleaning did not seem adequate). I have voltage to the injectors. I have ordered noid lights to check coil and injectors more accurately. Is there a way to check if computer is functioning correctly? Thanks, Larry
Old Apr 26, 2023 | 12:10 PM
Jjdidtiebuckle's Avatar
Jjdidtiebuckle
2nd Gear
Crank no start
My V10 excursion cranks but won’t start. I have a new starter, new alternator, and a new battery in it and it still won’t start. I also replace the spark plugs and coil springs
Old Nov 29, 2023 | 01:05 PM
JTDCO's Avatar
JTDCO
1st Gear
Regarding PATS, as I understand it, key on light off if working. At present I have no pats light. I do have power at injectors. I have spark at coil. Not sure what IAC Is. Idle blank control??. Nothing at all when spraying into THB. Could it be PATS?? If so, can you please give me detailed instructions on how to check the PATS system or diagnosis.
Thank you, this has veen the only place who seems to understand what the issues are.
Patiently Awaiting
JTDCO
Old Nov 29, 2023 | 01:08 PM
Jjdidtiebuckle
2nd Gear
So you have crank no start as well?
Patiently Awaiting
JTDCO
Old Nov 29, 2023 | 04:22 PM
projectSHO89
Read the WHOLE thread....
Old Aug 13, 2024 | 08:16 PM
Dweinley's Avatar
Dweinley
1st Gear
I had the same problem
I’ve been having the same problem I was driving home truck shut off and check engine light came on for crank sensor changed it and still wouldn’t start took the belt off and started put the belt back on wouldn't start again my fan is super stiff think water pump is bad?
mooreswm
Modular V10 (6.8l)
Jul 27, 2015 06:16 PM
pointerman1967
Nov 20, 2014 05:21 PM
dreibyrd
Modular V10 (6.8l)
Dec 14, 2013 05:33 PM
tengel
Nov 27, 2003 03:13 AM
