confused
Old Feb 7, 2020 | 06:41 AM
hellskells's Avatar
hellskells
confused
hello guys, i have a 2013 f550, just got it back from the dealer for recalls, went for a drive and the truck died on the highway, couldnt get it to start as the engine wasnt cranking fast enough and killed the batteries, got it towed, installed new batteries and tried to start it. same issue slow cranking with a high pitched squealing noise while cranking, removed all glow plugs and fan belt, still having the same problem. suggestions needed please.
Old Feb 7, 2020 | 07:00 AM
kper05's Avatar
kper05
What are the DTCs?
Old Feb 7, 2020 | 10:34 AM
hellskells's Avatar
hellskells
p0263:00-6c, p0263:00-ec, p0266:00-64, p0269:00-64, p0275:64, p0281:00-64, p2459:-64 are the codes i have, all injector contribution/balance codes and one glow plug code.
Old Feb 9, 2020 | 01:27 AM
jsukey's Avatar
jsukey
Did you attempt to take it back to the dealer? That would’ve been my first move.
Old Feb 9, 2020 | 07:06 AM
senix's Avatar
senix
take it back to them, or better yet, have them come and get it. They broke it.
Old Feb 9, 2020 | 09:23 AM
The Bone's Avatar
The Bone
Sorry dude
What are you thinking. You just had your truck to the dealer than your truck dies on the highway. You then buy new batteries remove the glow plugs and a fan belt? Now you have so many codes you don't know where to start.
My suggesti9on is put down your tools and have the dealer come get this truck. Do not tell them you wrenched on your truck or they will tell you messed up your truck and they won't fix it.
I am not sure what glow plugs had to do with the truck not starting after driving down the highway. If the truck is warm they don't come on to start the truck.
Again I am sorry for the rip Hellskells.
You may have cost you more money than having it towed to the dealer in the first place.
Good luck with this.
Old Feb 9, 2020 | 12:38 PM
brandonrr's Avatar
brandonrr
I've got a bad feeling about this one...
Died on the highway, followed by slow cranking with a squeal, even with the belt off. I hate to say it, but I think there may be heavy engine work in your near future. I hope I'm wrong.
Old Feb 10, 2020 | 04:23 AM
ckduallie's Avatar
ckduallie
HP fuel pump/system?
Old Feb 10, 2020 | 10:50 AM
bobcat67's Avatar
bobcat67
I'm thinking the CP4 and injectors just took a dump
Old Feb 10, 2020 | 04:56 PM
wylecoyote's Avatar
wylecoyote
Slow cranking could also be a defective starter. Just to be on a positive note.
Old Feb 11, 2020 | 01:25 PM
hellskells's Avatar
hellskells
i would really hope so. But i dont think that would cause the truck to die on the highway.
Old Feb 11, 2020 | 01:32 PM
hellskells's Avatar
hellskells
Thats my exact thoughts. Thanks
Old Feb 11, 2020 | 01:38 PM
hellskells's Avatar
hellskells
well the hp ssem is gear driven.
Old Feb 11, 2020 | 01:39 PM
hellskells's Avatar
hellskells
supposedly they only changed a o2 sensor recall
Old Feb 11, 2020 | 01:41 PM
hellskells's Avatar
hellskells
what were you thinking con and main bearings
Walleye Hunter
42
Feb 1, 2019 01:43 PM
Mbn4211
6.7L Power Stroke Diesel
Aug 4, 2018 11:58 PM
alanc77
Apr 12, 2007 08:55 AM
minifarmerusa
13
Mar 2, 2007 02:15 PM
Dave7.3
54
Jan 10, 2007 10:47 PM
