Travelling
Old Feb 6, 2020 | 03:43 PM
cycletom0's Avatar
cycletom0
Travelling
Hi I am in Quartzsite when my e350 just up and quit no power at all. Turn the key on and nothing. Good battery 12.7. Absolutely nothing. Checked all fuses under the dash all good. Has anyone a clue to what has happened as I would like to try and fix this myself. Any suggestions would certainly be appreciated. Thanks Tom
Old Feb 6, 2020 | 06:12 PM
Benztechnc's Avatar
Benztechnc
So you have an E-350. What year, what engine?
Going down the road the engine quit, and won't restart. Does the starter spin? Does the igntiion (Lights etc) come on? Or is everything completely dead and gone?
Old Feb 7, 2020 | 12:07 PM
cycletom0's Avatar
cycletom0
The starter will not spin and I get no lights on the dash. Checked all the fuses all good. The battery is at 12.7 no headlights no marker lights dead as a door nail. Thanks Tom
pulled the computer out nothing burnt, looks like new.
Old Feb 7, 2020 | 01:11 PM
rla2005's Avatar
rla2005
Bad battery, cable(s) and/or connections. What is the battery voltage, 12.7 is a bit low to me, when you turn the headlamps on? Measure at the battery terminals, then again with a lead on a good frame or body ground.
Old Feb 7, 2020 | 01:36 PM
irhunter's Avatar
irhunter
I would start by getting a jump; that will for-sure let you know the battery is not the problem.
Then, as RLA suggested, clean both ends of the battery cables.
Check for power at the fuse block. That van have a fusable link?
Roy
Old Feb 7, 2020 | 03:57 PM
FuzzFace2's Avatar
FuzzFace2
If you are getting 12.7 is that on the posts of the battery or on the clamps of the cables?
If you have nothing I would pull the cables off the battery and clean the connections as a start.
Could also clean the other end of the cables while at it.
If still nothing then check power from battery cable clamps to grounds & starter relay (solenoid) following the path the power would till you find the open line.
You may need to do the same with the fuse links at the relay to see if 1 of them went bad. One of the links supplies power to the inside to make everything work.
Dave ----
Old Feb 8, 2020 | 01:27 PM
cycletom0's Avatar
cycletom0
Thanks for all the sugestions had a mechanic come in and went right to the problem an in line fuse under the battery. Who would put one there only Ford right!!
guyina4x4
2004 - 2008 F150
18
Feb 26, 2019 01:37 PM
DG93
Aug 17, 2015 08:45 PM
XenonKilla
Electrical Systems/Wiring
Apr 8, 2010 02:48 PM
Mydirtytruck
Modular V10 (6.8l)
20
Sep 20, 2007 09:05 PM
