How do the weathertech look from the front/inside? One brand has a metal piece that I'm not a fan of. Wasnt sure if WT or another? From rear IMHO WT look the best.
I have had Duraflaps on my last three trucks. I like the extended length option. I just got delivered today the rear flaps for the 2020 F450 I have on order. Was hoping the factory fronts would be good but sounds like I may have to order the extended width Duraflaps for the front here soon.
Three total screw heads. That’s all. One extra screw head is added. The other two screw heads are reused stock screws already in place.
If ordering, just go with the factory flaps. Nice quality. I didn’t because I enjoy mounting my own accessories.
The OEM flaps are a no-drill install. All of the required bolts and clips are provided.
Thank you, appreciate quick response! Did you go with flat or molded ones? And the pictures provided by SuperDuty Wannabe and ForCal - are those mud flaps flat or molded? I am on Ford accessories page, and honestly I cannot tell the difference. Problem I see is that flat ones are the same model number for both front and rear, while the molded ones are different. And molded front pair without fender flares is not even listed as option. It's kind of confusing... I'd like to go with OEM since I have all those fordpass points to use up...
