95 E40d possible mlps issue
Old Feb 2, 2020 | 11:14 AM
JimiLL's Avatar
JimiLL
So I’m having the classic symptoms of a bad mlps.... slipping, hesitant upshifts, tc lockup at odd times, etc. This condition started overnight, after a drive home in some wintry conditions. Replaced the mlps, still nothing. The trans shifts through all gears, reverse, and will even cruise 70 mph with full tc lockup. Symptoms seem to come and go, and trans fluid is clean although higher than I remember after doing a service maybe 5k miles ago.
The problem seems electrical with it being as sporadic as it is. Where can I go from here?
Old Feb 2, 2020 | 12:11 PM
westcoasting's Avatar
westcoasting
Do all your lights work? I had the same issues and it was my top brake light was burned out!!
Old Feb 2, 2020 | 01:45 PM
JimiLL's Avatar
JimiLL
you know what, that sob doesn’t work. The white bed lights work, but not the actual brake light.
how does that relate to the trans?
Old Feb 2, 2020 | 03:25 PM
torq'ta 5 8's Avatar
torq'ta 5 8
in ford engineers wise-less-ness, they tied 3rd brake light with E4OD and its shifts, thats another reason people have issues when putting LED's in, then have E4OD trans shift issues
Old Feb 2, 2020 | 10:26 PM
westcoasting
Lmao i know its the craziest thing ever!! If that non functioning light doesn't fix the problem right now it will fix the problem that will surface very soon if you didn't!!
Old Feb 4, 2020 | 01:17 PM
JimiLL's Avatar
JimiLL
ok unfortunately bulb did not fix anything.
Old Feb 4, 2020 | 01:33 PM
88n94's Avatar
88n94
So does the light now work when you step on the brakes?
Old Feb 4, 2020 | 01:38 PM
sandymane's Avatar
sandymane
Here is a possible solution to consider. You should run diagnostic codes to see if any of these apply to you. Sandy
https://www.ford-trucks.com/forums/1...s-harness.html
tjc transport
16
Dec 6, 2017 10:48 AM
trackenator
Dec 12, 2009 09:57 AM
Hillbily72
Jan 8, 2007 05:32 PM
BK50
Aug 17, 2004 09:30 AM
