I just found out that I am not getting positive traction on the rear axle after spinning out of a friends back yard. I recently replaced the rear axle cover and filled it with Mobil 1 gear oil which has the LS additive.I have researched and it seems the LS wearing out is a common issue especially with the miles I have on the truck. Judging by the condition of the rear axle cover it looks like I was the first one to take it off since the factory. My question is should I try adding more LS additive or go forth under the assumption that its just worn out?
just curious, what are signs or clues that would indicate the cover has never been removed ?
regardless of the covers history of being removed or not, if the LS clutches are worn out i do not see how adding additional friction modifier would help since its purpose is to let the clutches slip. if they clutch material is worn out then there is not material to grab and they are already slipping.
if the clutches are worn out replacement is required.
you may need to add Fords FL-3 friction modifier to gear oils that say they have some form of LS friction modifier already in them, you will know you need to do this because the LS will chatter without the correct modifier. not adding the correct modifier to your oil will kill your clutches.
I'm sure the clutches are worn out, just wanted someone elses take on it I guess. As far as the cover I can't say its never been off of course but I am guessing it had not. Sometimes it's obvious that it has due to excess sealant being used/smeared around the sealing surfaces. Orange sealant smeared againt black paint really stands out lol. I actually looked at a 7.3 on a lift at a Ford dealer before I bought this one. It was obvious that the rear end had been gone into since the factory. I mentioned it to the two mechanics there and they said they didn't know of any common rear axle issues on these trucks. Hindsight thats hard to believe they didn't if they were worth their salt but I guess its possible.
The factory limited slip doesn't work that well to begin with, and they are usually worn out by 100K. They aren't that hard to rebuild and you can add extra shims to tighten it up so it works better, just don't shim it to tight or you end up with a spool. I rebuilt mine and shimmed it really tight so the tires were skipping around corners it was great for the extra traction but the skipping was hard on the tires, I put a Detroit locker in and it works much better, I get full traction in the rear all the time yet it will still unlock around corners and not skip the tires. The Detroit Truetrac is also a good unit if you want a limited slip.
The easy and cheap answer is just to live with it. If you plan to keep the truck you're looking at $2500-3000 to have a pro drivetrain shop tear it down and rebuild it from scratch with a Detroit True-trac or locker. Big project obviously and not inexpensive.
2500-3000? Lol, a limited slip rebuild kit costs around $250 and is easy to do yourself. A Truetrac with new carrier bearings and shim kit is $800 at most, and if you don't want to do it yourself a shop shouldn't charge more than 3-4 hours of labor.
Maybe that's a little high but it depends how deep you wanted to get into it. Mine had to come completely out of the truck to fix the passenger side spindle at the machine shop and the bill was just shy of $1900 to totally rebuild it minus the ring and pinon. Luckily I wasn't on the hook for that one. If it was just a Truetrac and new carriers...1200-1300? If was going to bother taking it apart I would put the good one in there.
