Remote start Forscan help
Old Jan 31, 2020 | 07:02 AM
Cmf250's Avatar
Cmf250
So last night I installed the factory remote start with long range antenna and 2- way fob. The truck starts using lock/ unlock/ lock on the original fob and using the new 2- way fob. My problem is the dash is not displaying the remote start in the menu. I enabled the remote start and lights in Forscan using the config tab. What am I missing?
Old Jan 31, 2020 | 08:16 AM
brandon86305's Avatar
brandon86305
You need to write these values in the asbuilt data in Forscan: BdyCM 726-22-02: xxx1 xxxx xxxx and IPC 720-02-02: xxxx Axxx.
Old Jan 31, 2020 | 12:22 PM
Cmf250's Avatar
Cmf250
I'll give that a shot. I thought enabling the module would have been enough. Thank you.
Old Feb 4, 2020 | 04:51 AM
Cmf250's Avatar
Cmf250
The IPC module was the fix. Enabling the remote start in config must change the other module because that was already written.
troverman
2009 - 2014 F150
Jan 2, 2020 07:35 PM
rw1988
Nov 14, 2019 08:44 AM
hobbie1
May 30, 2018 12:03 PM
dh_meyer
2009 - 2014 F150
Dec 15, 2015 11:44 AM
BURNSTOUGHFORD
2009 - 2014 F150
24
Feb 16, 2013 06:58 AM
