Interior door handle sticking
Old Jan 28, 2020 | 04:41 PM
Sean Wilcox's Avatar
Sean Wilcox
I bought a 93 7.3l IDI about a month ago, I did some regular maintenance that is needed around 100,000 miles including an oil change once I bought it new glow plugs and I’m soon to do the injectors but I just ran into an issue for the first time, the door handle on the interior drivers side became extremely difficult to pull and it sticking in some spots, I got it to where it will open now but it still is making some noise and not opening smoothly, the door panel is loose which may indicate something has been done to it before and I’m assuming that it’s just a cable but I want to be sure before I buy the parts since I’m a broke high schooler lol
Old Jan 28, 2020 | 04:59 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
my 93 is Cable..... https://www.lmctruck.com/1980-96-for...oor-components
Old Jan 28, 2020 | 05:07 PM
Sean Wilcox
Unfortunatly it is a different linkage then what I have
Old Jan 28, 2020 | 05:21 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
OK so your 93 uses the rod not the cable.... both styles are listed on the page I posted...
you can search FleaBay for the parts you need too, post some pictures maybe others will know what you have
LMC seems to indicate some of that stuff is interchangeable too.
Old Jan 28, 2020 | 06:27 PM
Sean Wilcox
oh it came up for a rod for me when I believe I have a cable, I think I’m gonna end up using one I found on amazon for relatively cheap and see what happens, hopefully it’s just the cable thanks for the help
Old Jan 28, 2020 | 06:33 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
OK I see... this is the image I got....
Old Jan 28, 2020 | 06:35 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Item 14 is just the cable item 13 is the complete assy with the cable and and operator (item 12) and Yes they are pretty proud of the Assembly
Old Jan 28, 2020 | 06:39 PM
Sean Wilcox
Yup, I’m gonna try throwing some lube in it first if that don’t work then imma buy a new cable and cross my fingers either way it’s a cheap fix thank god
Old Jan 28, 2020 | 08:11 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Your driving the wrong vehicle for a broke high schooler but you're only young once lol. Yeah,don't buy anything yet just spray the wd-40 in there from the opening at the latch and keep pulling the handle in and out to see if it just frees up.Probably will.What happens when the cable goes bad is it stretches,then you need to pull on the handle harder than you should.That then leads to either breaking the handle or the too thin sheet metal it's mounted too.In that case,you'll have to pull the door panel off to take a look to see whats up.They might be cheap but those little cables are a PITA to change.Tight spot and you have to stand on your head,look cross eyed and twist in two or three different ways to get the things hooked.You'll be cussing and carrying on and a having a good old time.
Old Jan 28, 2020 | 08:27 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Yeah Buddy
And chances are good that other seals are bad allowing weather in to cause more problems than just a cable.
Old Jan 29, 2020 | 04:33 AM
Sean Wilcox
yeah that’s what I think I’m gonna do, and I’m only broke because of the truck lol.
husker3in4
Escape & Escape Hybrid
Jun 11, 2016 08:58 PM
shark1979
1983 - 2012 Ranger & B-Series
May 28, 2009 08:21 PM
tcoates
Mar 4, 2009 05:43 PM
1978Crew
Jan 24, 2008 11:46 AM
jonathandennell
Nov 9, 2006 06:07 PM
