I have had a 1976 f150 for a bit over a year now and I'm not sure how to identify the engine in the truck. I'm pretty positive it is an FE but I would like to find out whether it is a 360 or a 390. It has a 4bbl carb on it which the 360's never came with so either it has some after market modifications or it could possibly be a 390. Are there any tests I could do to find the displacement and would the casting numbers on the block tell me anything about it? Any help would be much appreciated.
Thanks for the information. I'll be sure to check out that wire method and determine with what I'm working with. I don't know if there are casting numbers on the intake manifold and I'm not around the truck right now to check. What would those casting numbers indicate for when I'm able to check it out in the future?
The casting number would tell when the part was revised, and what it was designed for in the first place. You have a '76 vehicle, so if the manifold casting number is C6AZ or C3AZ (unlikely) you could safely assume it was added after the fact.
