Hello! I have a 1993 Ford F-150 4x4 5.8L 351W w/e4OD auto.
The truck was idling one morning before work and I walk outside and it’s off. Found to be getting good fuel pressure at rail and good spark to distributor from coil but very weak spark at plugs. I’ve replaced the distributor, cap, rotor, plugs, wires, and coil. But am still getting weak spark to my plugs. Any ideas??? Made sure base timing was set properly. Truck cranks but won’t fire, sometime pops on #1 cylinders at first crank but that’s it. Any ideas??
