Sponsored by: Halo Lifts
Shaking while towing a trailer
Old 01-30-2020, 08:54 AM
dmd's Avatar
dmd
dmd is offline
Originally Posted by JKBrad
So many ST tires are made in China and just don't hold up. LT tires have a better speed rating and generally last much longer.
Also ST rated tires have a max speed rating of 65mph. I had no issues with ST tires until I moved to a state that allowed towing faster than 55-mph.. Towing at
65-70 and I blew two of them in one trip.. LT tires now with steel sidewalls (Michelin Ribs and Bridgstone sell them) no issues.
Old 01-30-2020, 11:38 AM
TJReams's Avatar
TJReams
TJReams is offline
It could also very simply be the way the air flows over these new trucks. Stick a piece of plywood Sheet or partial in the bed with the tail gate up with about 5-6 inches sticking above the tailgate and see if that cures it.
TJ
Old 01-30-2020, 07:13 PM
cullenkyla's Avatar
cullenkyla
cullenkyla is offline
I had the same thing happen . I balanced the trailer tires problem solved
Old 01-31-2020, 01:06 AM
CathedralCub's Avatar
CathedralCub
CathedralCub is offline
Originally Posted by jyarosz
Goodyear has a new trailer tire that has been out a few years.They are called there Goodyear Endurance.They have a higher weight rating compared to most other trailer tires and are made in America.I have them on two of my trailers so far and they all balanced out near perfect.
That's good to know!
Old 01-31-2020, 01:10 AM
CathedralCub
I'll add one more vote for balancing the trailer tires. Out of round will make for some up/down action, but most of that won't be felt in the tow vehicle. Unbalanced will also make for up/down, but will also give a lot of forward/backward action as forward/backward isn't dampened much by load weight and isn't dampened at all by being pressed against the ground.
Jd4230
2017+ Super Duty
38
03-02-2024 01:19 PM
pdarby
2017+ Super Duty
05-02-2018 01:55 AM
REDFORDFX4
2015 - 2020 F150
07-16-2017 01:48 PM
dhayse32
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
06-27-2017 10:50 AM
Slavoise
2017+ Super Duty
06-18-2017 09:16 PM
Quick Reply: Shaking while towing a trailer
