Cab mount bushing question
Old Jan 27, 2020 | 06:23 PM
the_old_ranger's Avatar
the_old_ranger
Has anyone used the Energy Suspension cab mounts?
They got em here at Jeg's
https://www.jegs.com/i/Energy+Suspen..._wcB#reviewTab
I guess these are polyurethane. I don't want to use the Kevlar mounts and I certainly don't want to go back to OEM mounts cause I doubt if there are any better than the originals. There are only two reviews there and one guy says they are noisy.
Well crap I put this in the OBS section sorry I gotta move it
Last edited by the_old_ranger; Jan 27, 2020 at 06:25 PM. Reason: Wrong trucks here
Old Jan 27, 2020 | 11:00 PM
Hit Man X's Avatar
Hit Man X
I slapped em on the F350. No more noise than stock. 👍
Old Jan 28, 2020 | 08:27 AM
the_old_ranger
Great I'll order a set
Old Jan 29, 2020 | 09:31 PM
z31freakify's Avatar
z31freakify
Did the rear cab with Energy's worked great, still haven't had time to do the front ones yet.
Old Jan 30, 2020 | 11:31 AM
the_old_ranger
Did your rear mounts go out first?
Old Jan 30, 2020 | 12:00 PM
z31freakify
Yup, chassi looked like it was bent. The cab to bed lines were an an inch and a half (iirc) height difference.
Old Jan 30, 2020 | 12:27 PM
the_old_ranger
OK thanks. Damn this truck!
Old Jan 30, 2020 | 12:28 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
This is not a job for the faint of heart. I did it on mine as I stated, I think ONE came off with the puller tool. Other five had to be cut off.
Old Jan 30, 2020 | 02:21 PM
the_old_ranger
I'm feeling faint of heart about this whole cotton picking truck
Thanks!
Old Jan 31, 2020 | 10:17 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Extended cab requires rear seat removal. I think Adam did it with the rear seat installed as his has a crew cab. No idea what regular cab entails...but I would guess seat removal.
Core support ones had to be sawed off mine. This truck was bought new in Georgia and went to Alabama, then Texas. No northern usage.
Old Jan 31, 2020 | 01:40 PM
the_old_ranger
Ok thanks Hitman! The rears are the ones going bad but they are gonna have to wait as I need a low pressure fuel pump module I Guess. The only scantool I have is Forscan and I don't think it will do low pressure test. Least ways never did we it I'm gonna nhook it up later see what...
Dadgum pos
Old Feb 1, 2020 | 12:46 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Which truck is this you are working upon? What fuel system is on it?
Old Feb 1, 2020 | 06:34 PM
the_old_ranger
This is my 2012 F-250 completion stock fuel system. I am just hearing a "squeak " from the right rear with no clunking noise,yet. So I am not Absolutely sure the mounts are even bad . The squeak I thought was the rear seat first but can't find anything wrong there. So I got under the truck visually inspect and the clearance in the bushing on the right rear is very minimum if you know what I mean as in the clearance between the metal cup and body I cannot really see the mount. I gotta get under there and pry around before I buy bushings. Gonna do the FCIM first.
Thanks, Larry
Old Feb 2, 2020 | 09:49 AM
Hit Man X's Avatar
Hit Man X
Ahh, that 2012 should be pretty easy to do mounts.
My 6.4 used to eat the radiator support mounts all the time. Crushed the radiator once too, expensive fix!
the_old_ranger
6.7L Power Stroke Diesel
23
Feb 1, 2020 06:37 PM
f100today
May 28, 2016 08:07 AM
thendrix
Oct 14, 2007 09:14 PM
1972ford_f-100
Mar 22, 2004 09:28 PM
