Speedometer is way off after dash work
Old Jan 27, 2020 | 10:55 AM
jackstar's Avatar
jackstar
1977 f250 400 auto 2wd. I had a/c put in my truck and the dash was pulled. Now the speedo starts at 85mph and sweeps to the left upwards clockwise as I drive. How can I fix this back to zero and be accurate? I have searched the forums and have not found anything like this that does not involve tire sizes and changes. Thanks Jack
Old Jan 27, 2020 | 11:10 AM
wyrm73's Avatar
wyrm73
CAREFULLY pull the needle off the front of the gauge and see if it can be re-positioned. I recall that able to remove it pretty easily when I was painting my gauge needles, but I don't recall for sure if there is any kind of indexing slot or something that would prevent your from just turning it to point back at zero. I don't think so, but I'm not totally sure either.
Old Jan 28, 2020 | 10:57 AM
tlrtucker's Avatar
tlrtucker
Before you do that, simply disconnect the speedo cable from the back of the gauges and reconnect. My speedo was doing weird things after I pulled the gauges out and reinstalled. I disconnected the speedo cable and noticed it wasn't seated in the gauge correctly. After I reinstalled it everything worked as it should.
Is it possible to put it in upside down?
Old Jan 28, 2020 | 06:57 PM
72rtchallenger's Avatar
72rtchallenger
I would do as suggested and disconnect the cable at back of cluster , it could be in a bind I suppose, perhaps pull cluster and test speedo while out with small screw driver
GoldCo
May 5, 2017 07:15 PM
Litlgar
Apr 19, 2015 07:11 PM
hawgystyle
Dec 27, 2010 12:14 AM
55 f350
Nov 28, 2008 07:08 PM
