Starting Issue (video provided)
Old Jan 26, 2020 | 05:06 PM
TooManyToys.'s Avatar
TooManyToys.
Old Jan 26, 2020 | 05:35 PM
bigheadwrangler's Avatar
bigheadwrangler
This makes sense! Well I guess it’s time to take it in somewhere
Old Jan 26, 2020 | 05:44 PM
bigheadwrangler
By the way, well done editing my video lol
Old Jan 26, 2020 | 06:16 PM
TooManyToys.
Thanks. Sometimes it’s easier to show things visually then explain.
Old Jan 28, 2020 | 02:23 PM
bigheadwrangler
Well I drove it today, did the same thing however when I fired it up after work I got a #5 P0275. I touched the skinny pedal and it smoothed out. Drove the truck home, no issues. I got smoke coming out of the tail pipe on start up but it goes away after a little drive. I'm done driving this thing until I get it fixed. I don't want to cause more damage. I ran the passenger battery to starter cable test when I came home and it was an even crank with no weird jumps or skips.
Old Jan 28, 2020 | 03:04 PM
TooManyToys.
It’s not a big enough leak to occur unless a long sit time. Do the fender start after overnight, and you’ll probably have the uneven crank.
However, I wouldn’t. Every time you go through this high pressure clearing, you are risking a head gasket. You got a cylinder code, #5. Yank the glow plug on 5 and crank cold to see if you get fuel spit out to confirm the cylinder. Change that injector. Two bills and some time.
Old Jan 28, 2020 | 03:07 PM
TooManyToys.
Second thought, the problem yanking the GPCM is the risk of little plastic parts falling into the oil pan. It’s not so much of a risk, but it’s more comfortable situation if you pull the valve cover and plug the drains so little parts can’t drop through before pulling the gp harness.
Old Jan 28, 2020 | 04:08 PM
bigheadwrangler
Yeah I don’t wanna blow a head gasket. I don’t really have the time to do this repair myself but I can diagnose it at least (by your suggestion). Should nothing come out of the cylinder when I do the fender crank?
Old Jan 28, 2020 | 04:32 PM
TooManyToys.
If it's leaking fuel in there, yes! fuel will come out!
Old Jan 28, 2020 | 08:17 PM
Brotherbillstruck's Avatar
Brotherbillstruck
I have not had to crank the engine with a glow plug removed but I think I have read the fuel will be expelled at a high rate. NO body parts near.
Frantz
6.7L Power Stroke Diesel
Oct 28, 2016 07:35 AM
lazerf250
Jul 4, 2007 09:26 PM
