Sponsored by: Real Truck
2001 f350 5.4 wiring problem
Old Jan 25, 2020 | 08:50 PM
4x4k20's Avatar
4x4k20
got a 2001 f350 with the 5.4 i cant get any power to the fuel pump and the start wire thats goes to the starter solenoid when i turn the key it does nothing . i have checked all of the fuses and relays and the fuel cutoff switch the only thing i done was replaced the fuel pump and the key switch . i also checked the neutral switch wiring it wont do anything in park or neutral . i cant find any wiring diagrams for this truck on line they all want to charge me something so if any body can help let me know thanks
Old Jan 26, 2020 | 06:29 AM
cmaupin's Avatar
cmaupin
May need to look into a service manual. Ebay has it 15$ its alot better than those paper book
try this
https://www.ebay.com/itm/2000-2002-F...item1a8e62791a
Old Jan 26, 2020 | 08:12 AM
projectSHO89's Avatar
projectSHO89
Most of the needed schematics for this type of issue have been posted in this forum by users over the years. It may take some persistence in SEARCHing to find them..
Do you have a multi-meter (or test lamp) and know how to use it? Without that tool and some basic knowledge, it's pretty much impossible to do anything beyond first-level visual checks or "replace and pray".
Start by doing a careful and complete inventory of what does and does not work (electrical).
Old Jan 26, 2020 | 06:26 PM
4x4k20's Avatar
4x4k20
i went out today and removed the inertia switch and cycled the switch a few times and put it back in and the fuel pump has power now .so i lucked out there ... now i just need to find out why i am not getting power to the start wire on the solenoid ,.i am gona get a new nss switch and hope that it is bad . thanks for the replies
Old Feb 2, 2020 | 10:22 PM
cmaupin's Avatar
cmaupin
I recommend to check the fuse panels wires under and ground wires
Alto
1983 - 2012 Ranger & B-Series
29
Jul 6, 2013 10:16 AM
1CrazyLady
Jun 2, 2012 11:07 AM
dkchance74
Jun 16, 2011 03:47 PM
tjc transport
Nov 15, 2010 02:33 PM
