Manual clutch bleeding help
Old Jan 25, 2020 | 05:18 PM
925.8's Avatar
925.8
Hi, i can’t find any videos on how to bleed the clutch fluid on a 92 manual and need to because my pedal is very light and i can’t shift into gear any help or how to’s would be great. Thanks!
Old Jan 25, 2020 | 06:17 PM
sloopdog1's Avatar
sloopdog1
Google "Bleeding the clutch on 1992 F150". That should show many links.
Old Jan 26, 2020 | 10:27 AM
Mudsport96's Avatar
Mudsport96
I used a mighty vac pump to start mine when I changed slave cylinders. Hook up to bleeder and pump away.
Old Jan 26, 2020 | 02:05 PM
jas88's Avatar
jas88
What engine/trans do you have? The procedure is different if you have internal or external slave cylinder.
Old Jan 26, 2020 | 03:01 PM
88n94's Avatar
88n94
^^^^ That would be helpful, but from your username I assume you have a 5.8 engine? That would mean an internal slave cylinder. My question would be have you checked the fluid level in the clutch master cylinder? Usually if the fluid level has dropped too low causing your condition, you can just add fluid and pump the clutch pedal several times and drive normally and the pedal will work OK. The more you drive the pedal will return more to normal, that has been my experience anyway.
Anyway how did this come about? Have you checked the fluid level in the clutch master cylinder?
Scott Stewart
Jan 26, 2012 06:06 PM
ron01sd
Feb 10, 2010 08:33 PM
gangrene
Mar 17, 2004 06:49 PM
sethro
1983 - 2012 Ranger & B-Series
Oct 15, 2002 02:03 PM
