Transit Connect 2010+ Ford Transit Connect
Low Boost, solved
Old Jan 24, 2020 | 04:04 PM
Elkad's Avatar
Elkad
Low Boost, solved
2014 TC, 1.6 ecoboost, 150,000 miles.
Got a low boost condition, with CE light. My cheap OBD2 and phone app was reporting 1.8bar, well under spec. But not gone.
No noises or anything like that.
Drove it about a week like that before I had a chance to get under it.
Terrible on the hills of WV.
As soon as I got it on a lift, it was obvious. Intercooler hose on the port side had clearly backed off by a half-inch. Clamp was still tight enough I couldn't move the hose with my hand, but apparently loose enough it was backing off.
Loosened the clamp, seated it correctly, tightened as much as I felt safe on ABS plastic. Hooked up a better OBD2 tool, took it for a drive. Requested vs delivered were never off by more than 0.4lbs. It held 18.7lbs from 20mph to 80mph.
Fixed.
I had it in the shop for trans work 4 months ago. I'm guessing they had that hose off getting the trans out, and just didn't quite tighten it enough, and it's been working it's way off ever since.
Grannygear
Dec 17, 2016 10:58 AM
yme450
Oct 25, 2010 06:23 PM
bigpowerstroke
Jan 6, 2010 07:25 AM
zx250
Mar 23, 2006 06:44 PM
John Kiernan
May 16, 2005 10:48 AM
