Hey fellas I have searched and searched and found several related threads but never what fixed the issue. I have a 86 F250 with the 351 HO and a C6 auto. When I bought the truck the flexplate was missing a few teeth. I replaced the flexplate and the starter with a new Delco Remy starter (part# 25402 for an auto trans) Everything back together and the truck will start but it sounds horrible while cranking like the starter is grinding. My starter is a 9 tooth and I did find reference to replacing the starter bendix with a 10 tooth ( part #SDN-241) I have done this to many 80s rangers and it worked like a charm but wanted to get y'alls advice before I did it.
I'll have to do some digging to see if I can find the post, but read one recently where(and I honestly can't remember the application) the bellhousing or backerplate caused an issue with the starter alignment. I believe the starter didn't sit perpendicular to the flexplate and the solution was to shim under the starter. I'll see if I can find that thread again.
*Edit*
So far the top issues are ring gear, misaligned starter, loose starter bolt, bad connection at battery losing voltage, and incorrect starter. Did you compare the new one to the old one? And was there anything wrong with the old one when you replaced it?
So the starters are different for different transmissions, stick & auto, I also believe the "backing plates" are different also.
Also on the starters how can you tell if it is for a stick or auto?
Just because they say it is for an auto it could be for a stick no?
Just my .02
Dave ----
I can't say that I have heard anyone else have this problem, but the PO on my truck installed a starter that had a housing around the starter gear that was too long and slightly brushed the Converter. Horrible sound. I doubt that is the case here, as you put the starter in yourself, but it is a possibility. I would shine a light into the hole on the trans when you have the starter out to see if the converter makes contact.
*Edit*
Ring gear (flexplate) is new and compared to the old one the same except obviously in better shape.
Don't really see how the starter can be misaligned as it is 2 bolts with no adjustment and it has been in and out several times with the same noise.
Bolts are tight.
Voltage drop on all cables check out good.
Starter is a good name brand (Delco Remy) and from all I can find the correct one for my application.
Just my .02
Dave ----
Stick and auto have different length nose cones and I've compared the one I got to the old starter as well as the starter out of my 87 with a manual. It appears I have the correct starter.
