Electrical experts step inside.
Old Jan 23, 2020 | 07:42 AM
hail destroyer's Avatar
hail destroyer
Newer wiring harness. Burned spade connector on a 6 position 2 position plow headlight circuit. Didn't throw a fuse, wiring didn't burn, just and only the spade connector burned. ….....What would cause this?????
Thanks
Old Jan 23, 2020 | 07:44 AM
hail destroyer
Edit: 6 spade, 2 position plow switch.
Old Jan 23, 2020 | 07:57 AM
dlburch's Avatar
dlburch
Poor connection = resistance. Current flow through resistance = heat.
Old Jan 23, 2020 | 10:02 AM
beartracks's Avatar
beartracks
bad crimp.........
Old Jan 23, 2020 | 01:28 PM
1TonBasecamp's Avatar
1TonBasecamp
What they said.
But are you sure the wires are in that good of shape? They look awful rough from here. A bit blurry in the pic of course, and that may just be the type of jacketing on the wire that has the texture on it, but they do look a little ragged.
Paul
Old Jan 23, 2020 | 02:34 PM
wyrm73's Avatar
wyrm73
Could also be oversize fuse for the circuit and this is the weak point that showed the damage first. What size wire is that? Looks to be no more than 14 or 12 gauge, but kind of hard to tell. That should be no more than 15 or 20 amps respectively, but that is a maximum. A good idea in electrical wiring is to size the load at only 75% capacity max, so really only 11.25 & 15 A.
Edit: on second glance- is that the correct size terminal for that wire? I am thinking it is a 12 gauge wire in a terminal for 14-16 gauge. Combine that with high amps and cooked terminal.
whmayhew
Sep 25, 2016 09:52 AM
ProjectDaisy
Jan 18, 2016 04:35 PM
weyland426
Mar 3, 2015 11:51 PM
generaltso64
15
Apr 2, 2010 09:54 PM
mattsautobody442
2004 - 2008 F150
Sep 4, 2009 01:06 AM
