Driveshaft help??
Old Jan 21, 2020 | 04:40 PM
Matthew78's Avatar
Matthew78
Driveshaft help??
I have a 2 piece driveshaft from rear differential to transfer case output and a one piece from front of transfer case to the front differential. The two yokes in the rear should lineup correct? And should the yokes on the front of transfer case line up with the yokes on the output of transfer case?
Edit Quote
Old Jan 21, 2020 | 11:19 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Yes . . . ?
If I understand the question correctly. Perhaps some more detail would help here.
Old Jan 22, 2020 | 12:10 AM
Matthew78's Avatar
Matthew78
When I changed u joints my Mark's came off of the rear drive shaft at output of transfer case. I put the rear shaft with the yokes in line.(Back shaft is a 2 piece shaft). Do I line up the yokes from the rear differential to the transfer case with the front shaft from front of transfer case to front differential?
Old Jan 22, 2020 | 12:28 PM
CathedralCub
FTE Community Team
If I understand the question correctly: No, the differential input yokes can be aligned differently from one another.
Matthew78
Jan 21, 2020 11:18 PM
dpilot83
Feb 28, 2017 04:44 PM
j-kiser-01
Dec 22, 2006 10:04 PM
smallblock351w
Apr 26, 2006 10:02 PM
msmyth
Sep 3, 1999 07:20 PM
