Fuel pump relay?
Old Jan 21, 2020 | 03:25 PM
8285's Avatar
8285
Fuel pump relay?
1994 F150/4.9 engine, automatic. Having a weird issue with my fuel pump relay. Let the truck sit for a few hours and the fuel pump won't run.
-If I swap the relay out with any other identical relay in the box (horn relay for example) it starts right up.
-If I test whichever circuit is now running on the fuel pump relay (horn), it works fine. (!)
-If I shut if off and put the relays back in their original spots, it still starts right up.
I initially thought it was simply a bad fuel pump relay. However...
-If I let it sit for a few hours with the relays swapped, it won't start again and I have to swap them back. What on earth??? Doesn't seem to matter which relay I have in the fuel pump circuit, it won't start unless I replace it with a different one.
Any ideas?
Old Jan 21, 2020 | 03:31 PM
BOvalF250's Avatar
BOvalF250
4wd Low
Is the relay hot to the touch when you pull it out? This sounds like an issue I had with another vehicle of mine. The wiring had gone bad and the draw in the circuit was enough to overheat the relay. It would stop working for a little bit until it cooled down.
Old Jan 21, 2020 | 03:48 PM
8285's Avatar
8285
Hot? No. Warm, a little. If the relay was overheating, wouldn't that prevent the truck from starting when warm? It warm starts just fine and never stalls when driving, but let it sit for a few hours and you have to swap relays to make it start again.
Old Jan 21, 2020 | 07:23 PM
sandymane's Avatar
sandymane
Do you have dual tanks? The next time you go to start the truck, go ahead and try to start it. When it doesn't start, remove whatever relay is in your fuel pump slot and just put it back in the same slot and see if it will start. Sandy
Old Jan 21, 2020 | 07:28 PM
8285's Avatar
8285
Hi Sandy. It originally had dual tanks, but the rear tank has been disconnected (no fuel pump, lines are capped.)
I'm not so sure if the issue is actually relay-related at all. I inserted a brand new relay this afternoon, and it did nothing. It seems that power isn't always getting to the relay. My battery is at a healthy 13 volts.
Do the fuel tank selector switches on these trucks fail? I'm wondering if this is the issue.
Old Jan 21, 2020 | 07:29 PM
8285's Avatar
8285
Re: your directive to remove and re insert the relay. I've done this several times and it did not start.
Old Jan 21, 2020 | 07:41 PM
sandymane's Avatar
sandymane
Yes the switch can go bad. You can probably google for a schematic. The power goes through the tank select switch before it gets to the relay I think, but I don't know for sure. Sandy
Old Jan 21, 2020 | 08:10 PM
torq'ta 5 8's Avatar
torq'ta 5 8
could try to toggle the switch front/rear in the truck, when it wont start, it sounds like it may be carbonized up, could try spraying wd40 in switch and toggle front/rear, to try clean off carbon buildup, window switches will do this also, cant get them apart, just put the plastic straw on end to direct spray in the sides of switch
Old Jan 22, 2020 | 07:41 AM
rla2005's Avatar
rla2005
The fuel tank selector switch is after the fuel pump relay and the inertia switch.
I do not see where the OP actually measured the input voltage to the fuel pump relay coil or verified the computer (PCM) is applying the ground to the coil of the relay.
Old Jan 22, 2020 | 10:12 AM
sandymane's Avatar
sandymane
Thanks for the clarification Randy. I assume the OP should follow your recommendation for the above testing. Sandy
RedTaurus94
1983 - 2012 Ranger & B-Series
Aug 13, 2015 06:44 PM
smose
Electrical Systems/Wiring
Mar 27, 2004 04:43 PM
ksvtwin
Mar 19, 2004 09:52 PM
DM89909
Nov 20, 2002 06:05 PM
Avanti
Bronco II
Sep 8, 2002 11:13 AM
