cab lights
Old Oct 13, 2003 | 08:21 AM
bluemoose89's Avatar
bluemoose89
cab lights
i have a set of cab lights and the wiring harness from ford that i want to put on my f350. does anyone know of a pattern or a diagram that i can use i have tried ford and they dont have one or wont give it out. and has anyone tried to do this and know what steps to take and what your ran into and where to plug the harness into?
Old Oct 13, 2003 | 02:28 PM
jskufan's Avatar
jskufan
I would be curious to find out where the harness plugs into. I have clearance lights on my 2001 that have never worked. It may be something as simple as the harness being unplugged.
Old Oct 14, 2003 | 12:06 PM
thinksnow's Avatar
thinksnow
If you have the roof console they make a harness for the lights that plugs into that. I want to put lights on mine, I really love the look. Im just concerned with possible water contamination and rust in the long run.
Old Oct 14, 2003 | 03:29 PM
bluemoose89
well i dont have the roof console..but if you do it right and use the proper sealer it shouldnt be a problem with rust and water...uless whoever puts it in is a hack
Old Aug 19, 2006 | 03:38 PM
lance571's Avatar
lance571
cab light plug-in harness
The harness for cab lights on all f-series should be behind the passenger side floorboard kick panel. Easy to find and access.
Old Aug 19, 2006 | 03:51 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I went to the dealer and measured every dimension I could measure off a truck with facory lights, then went home and made a template from that.
Old Aug 19, 2006 | 06:26 PM
obxtant's Avatar
obxtant
6th Gear
Check out this site for instructions, pictures, and diagrams for your light installation. Worked out great for me on my '01 SD. Good luck!
http://www.emotoman.com/f250/lights/f250lights.htm
Old Aug 19, 2006 | 09:43 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Welcome obxtant to FTE!
bluemoose- check out this thread- https://www.ford-trucks.com/forums/4...earance+lights
robinsonpowerstroke
6.7L Power Stroke Diesel
Nov 8, 2014 10:06 PM
Finally Powerstrokin
Feb 8, 2013 10:11 PM
Island'r
Feb 5, 2013 09:05 PM
00Dave
15
Nov 16, 2012 10:42 PM
