F150 front end damaged
Old Jan 19, 2020 | 02:29 PM
RA022126's Avatar
RA022126
Banned
Sorry! 123456
Last edited by RA022126; Feb 20, 2026 at 11:01 PM. Reason: I’d like to remove all my content from this account
Old Jan 19, 2020 | 02:37 PM
ford390gashog's Avatar
ford390gashog
That is the reason grille guards are known in the insurance industry as damage multipliers. Do you have full coverage on the truck?
Old Jan 19, 2020 | 03:08 PM
RA022126's Avatar
RA022126
Banned
[QUOT
Old Jan 19, 2020 | 04:47 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Originally Posted by Gianni Velotta
Okay so this happened.
Yeah, don't do that any more.
I’d like to get as much done on my own cost efficient. How do y’all think I should do it? Should I just get what I need from the junkyard and call it a day or should I try a front clip conversion? Maybe just get a new hood and fender then get a iron cross style bumper?
Yeah, scavenge a good unit in a yard, hopefully with the same color paint.
Old Jan 19, 2020 | 05:02 PM
RA022126's Avatar
RA022126
Banned
[QUOT
Old Jan 19, 2020 | 07:00 PM
WWR's Avatar
WWR
Yeah, never understood brush guards. They're just for looks but are far over-leveraged to be able to withstand any real hit. A frame mounted, fully welded bumper, however....
I swapped one fender, headlight, and grille on my '07 after hitting a deer. It was easy but my damage was much less extensive.
Old Jan 19, 2020 | 07:45 PM
CathedralCub
FTE Community Team
A lot of halfway decent grill guards do okay, but the extensions are usually pretty weak until a lot of money is involved. Good for brush though.
Old Jan 19, 2020 | 10:30 PM
ford390gashog
i believe the grill guard is the reason I still have a truck...
Highly doubtful, grille guards are for looks and not structural in the least. The grill guard caused 80% of the damage to the truck which is known as secondary damage in the industry. Grille guards just fold right into the truck as you have found because they will pivot at the frame mounts.
Old Jan 19, 2020 | 10:49 PM
CathedralCub
FTE Community Team
I'm curious: What did it hit?
Old Jan 20, 2020 | 05:54 PM
steve(ill)'s Avatar
steve(ill)
Who said a 2009 front end will fit onto a 2008 ??
Also, raise the hood and look at the radiator and mount........ is the mount not damage to hold the radiator and head lights ?
Old Jan 23, 2020 | 10:56 AM
RA022126's Avatar
RA022126
Banned
[QUO
Old Jan 23, 2020 | 10:57 AM
RA022126's Avatar
RA022126
Banned
[QUOT
Old Jan 23, 2020 | 10:59 AM
RA022126's Avatar
RA022126
Banned
[QUO
Old Jan 24, 2020 | 08:33 AM
Slicefixer's Avatar
Slicefixer
I’m going to make it fit 😂 parts should be in next week I’ll keep you updated.
Supposedly bolt right up.....have to do a small bit of fabricating to mount the headlights.....
I'm in to see and hear about it so please post your thoughts and results...😉👍
Old Jan 24, 2020 | 10:05 AM
tlrtucker's Avatar
tlrtucker
Ranch hand bumpers are much different than light weight brush guards.
As far as the 09+ conversion - do some searching my man, there are a lot of threads and videos on youtube that detail this swap out pretty well. But basically, most everything will bolt on, but there will be some trimming required, mainly for the headlights. I bet some simple brackets will need to be fabbed up as well. If a 09-14 front swap is possible then Raptor parts should go on just as easy.
There are front end swap fiberglass Raptor kits out there made to bolt up - I'd start there. Not cheap tho.
