removing coolant crossover bar
Old Jan 18, 2020 | 10:53 AM
Chris6972's Avatar
Chris6972
Hi, I have a 2002 Ford Excursion 5.4 L gas engine. I've got coolant leak and local mechanic shop told me I need to replace gasket under the coolant crossover bar. Does anyone know if I can remove the bar without having to remove the air intake manifold with it? Thanks!
Old Jan 18, 2020 | 12:11 PM
Hamfisted's Avatar
Hamfisted
No, the intake must come off to access the crossover retaining bolts from underneath. Closely inspect the area where the crossover gaskets sits, for any cracks or broken plastic. If any breaks are found you may have to replace the intake manifold itself.
Ford 2L1Z 9424 AA intake manifold from Amazon Ford 2L1Z 9424 AA intake manifold from Amazon
Old Jan 19, 2020 | 05:16 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
You might want to plan on replacing the intake anyways. It might be sad about being disturbed, especially if it has a lot of miles (and heat cycles) on it.
Old Jan 26, 2020 | 06:36 PM
427John's Avatar
427John
I'm not familiar with Excursions but if they use the same intake as expeditions and f150's and you have to replace the intake you may want to try and find a 99 only aluminum PI intake they directly replace the plastic intake and eliminate the heat related issues that go with the plastic.
Old Jan 26, 2020 | 06:40 PM
ford390gashog's Avatar
ford390gashog
Replace the knock sensor while you have it off. It's a very simple job and you can be done in under 2 hours. I change the spark plugs at the same time when I do them.
codym84
2004 - 2008 F150
Dec 10, 2018 04:14 PM
7.3stroker2
Feb 4, 2016 04:28 PM
khxor
Feb 5, 2011 02:00 PM
Clint380
1983 - 2012 Ranger & B-Series
Nov 12, 2003 06:06 AM
