Seats
Old Jan 17, 2020 | 11:55 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Seats
Anyone using any aftermarket seats or from another year model vehicle? How do they fit? My 79 Bronco's bench seat is shot. Debating about upgrading to bucket seats.
Old Jan 18, 2020 | 07:28 AM
rob8210's Avatar
rob8210
Hey Manfred. I have a 1979 F250 4x4. I had a seat from a late 80’s Ford pickup in it for a while. All you need to do is use the mounting brackets from your bronco.
Old Jan 18, 2020 | 07:37 AM
caravaggio2000's Avatar
caravaggio2000
I'm also considering this. What is the first year for a bench seat that will work that has head rests?
Old Jan 18, 2020 | 08:15 AM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Pretty sure any bench seat up to 1996 with your rails on it will fit!
Old Jan 18, 2020 | 09:30 AM
alans77crew's Avatar
alans77crew
I put 96 explorer seats on tracks from a 78 bronco with buckets in my sc, the only thing I don't like is the explorer seats are high back and don't go as far forward as low back when you tip the passenger seat up.
Old Jan 18, 2020 | 09:32 AM
alans77crew
Don't try and use tracks from another seat as the bronco and SC are the same but standard cab tracks are different
Old Jan 18, 2020 | 11:29 AM
i-w's Avatar
i-w
very nice restore...
https://www.ford-trucks.com/forums/1...-are-done.html
I had these seats in my 79 but in cloth with wood center console.
https://shop4seats.com/truck-seats/4...uck-seats.html
Old Jan 18, 2020 | 12:36 PM
ManfredVonRichtofen
dang. My wallet isn't THAT fat!
I may just find something and fab some rails up.
What are yall classifying as SC?
Old Jan 18, 2020 | 02:46 PM
alans77crew
supercab they have the same floor as as a 78/79 bronco
Old Jan 18, 2020 | 05:51 PM
ManfredVonRichtofen
10-4. Summit has these pretty cheap https://www.summitracing.com/parts/sum-g1130r/
But then I might could find another vehicles bucket seats for the same price of that one seat from a pick n pull.
Old Jan 19, 2020 | 11:46 AM
alans77crew
your only limited by your imagination and ability! So storm on brother!!!
Old Jan 20, 2020 | 09:09 AM
scott79's Avatar
scott79
I went with a set of OBS (97 F350) seats for my 79 F350. Had to fab up a seat pan to bolt to the floor board (didn't want to drill new holes), then drilled and bolted my old track (with seats mounted to old track) to the fabbed pan, which was very easy then bolted down to the factory location holes. Check out the link below (post# 145).
Same concept for the bronco's. Just depends on what seats you like! If you prefer a center console (not a jump seat) you have options!! Get a console from any bronco. If you have a salvage close by, look at the 92-96 F150's, some of those came with bucket seats and console. But you get the idea!!
https://www.ford-trucks.com/forums/1...justified.html
Old Jan 20, 2020 | 10:18 AM
73 hi-boy 428 fe
Hey Scott,
Got any more picture of the way you mounted the seat to your new home made plate with original tracks? A picture of the plate would be nice also if you have it.
Old Jan 20, 2020 | 01:11 PM
scott79's Avatar
scott79
Sorry I don't! Was in a hurry to get them in the truck so I could drive it to a local truck show!
It was very simple. I had a local fabrication shop cut me a 18"x 54" HD grade aluminum 1/4" plate. Then I took a 18" x 54" piece of cardboard (matched to the aluminum plate) to create a template. Then sat the seats (OBS seats) on the cardboard (gently) until I could square up the seats to the cardboard (very important to get them square and make sure the bolts match evenly on the cardboard). Then after getting the seats square, I pushed down firmly on the seats so the bolts threads (on the bottom of seats) would puncture thru the cardboard. This created my template to drill the holes in the plate for the seats to be mounted to. I unbolted my factory bench from the track. Took the template and laid on top of of my factory track, then used a sharpie to mark the holes onto the template. Then double checked that the marks were square and straight to the plate...then drilled out all your hole mark locations. I mounted the seats to the plate first since there were more bolts to secure. Then I mounted the original tracks to the plate. Then put them in the truck for a test fit (ensuring the right height for me and to make sure the side-to-side was correct)! If everything is good, then just bolt down the track to the original factory hole locations!! Boom!!
Originally Posted by 73 hi-boy 428 fe
Hey Scott,
emeraldcoupe
Mar 4, 2010 02:45 PM
jetfiremuck
Aerostar
Nov 2, 2006 02:05 PM
1ole4d
Jun 5, 2006 02:35 PM
racerwad
Jan 27, 2005 08:24 AM
blueovalonly
Appearance & Dress-Up
Dec 22, 2003 06:58 PM
