Sponsored by: Real Truck
New Transmission
Old Jan 14, 2020 | 02:21 PM
ChaseII's Avatar
ChaseII
New Transmission
Hey y'all new here. I have an 08 F250 sd. 6.4 my transmission is smoked. I am very confused with trying to get a new one. I bought the truck used it has 10" lift and is suppose to have alot of motor upgrades. Looking for suggestions or recommend where to find new or rebuilt? Stage 1 versus stage 3. Thank you
Old Jan 14, 2020 | 02:26 PM
ford390gashog's Avatar
ford390gashog
Safe to say stock gear ratios? Improper tire diameter above stock will always smoke a transmission.
Old Jan 14, 2020 | 02:38 PM
Juneaudave's Avatar
Juneaudave
Can you describe what is going on? I'm not sure what "transmission is smoked" means.
Old Jan 14, 2020 | 07:33 PM
Yahiko's Avatar
Yahiko
I am guessing he took the clutches out with the large tires.
One thing I found out the hard way is Ford uses a spin welding process to attach the sun gear to the clutch shells.
The fix is to have them TIG welded to beef them up.
Old Jan 16, 2020 | 07:14 AM
ChaseII's Avatar
ChaseII
It started slipping, then lost gears by the time I got it to the transmission shop. It has 38x14x24 wheels. It went quick.
Old Jan 16, 2020 | 12:03 PM
Juneaudave's Avatar
Juneaudave
I think you maybe need to talk to a specialist on this. Without knowing truck condition, mileage, the transmission codes and recommendations from your transmission shop, budget, etc, I'm not sure anyone here can advise you. FWIW....If your looking for something beefed up to handle the large tires and increased horsepower, I have seen people on the board reference Brian's Truck Stop for custom transmissions. BTS custom builds transmissions for horsepower and tire size...might be worth giving them a call to see what they think and to give you advice.. E4OD | 4R100 | 5R110 Ford Diesel Powerstroke Transmissions
MurderMode
Feb 2, 2018 12:45 PM
Quantum77
Mar 14, 2013 04:11 PM
mudslinging79
Bronco II
Oct 30, 2008 11:07 PM
custom1
Sep 8, 2006 08:31 PM
