I've got '66 CC with 352 motor. I'd like to add an real temp gauge but keep the stock gauge operational. First where is the OEM temp sending unit? And second will I have to add a second one or can the gauge and OEM gauge share the current sensor?
If you need a second location for your added temperature gauge, you can find a thermostat housing that is threaded for the new sender. Don't try to use a "T" in the intake to support both senders.
