2003 no 4wd
Old Jan 13, 2020 | 12:39 PM
Lockholder's Avatar
Lockholder
2003 no 4wd
Been having a 4wd issue. Had it on jack stands and engaged 4wd and the front doesn’t spin. I replaced the motor, and the Driverside connector. Light comes on when key is on and when I turn the **** in the cab it kicks the light on. This is when the hubs are locked (manual locking warn hubs)
Old Jan 13, 2020 | 02:01 PM
pirate4x4_camo's Avatar
pirate4x4_camo
test light or multi meter and confirm the motor is being sent a 12v current when you select 4wd,
if no signal work it back to the relays, switch pcm/gem
if voltage bench test the motor for function
Old Jan 13, 2020 | 02:34 PM
Lockholder's Avatar
Lockholder
so I can hear the motor turning would that indicate it’s getting 12v?
ocm is brand new
I’ll try bench test
Old Jan 13, 2020 | 06:19 PM
pirate4x4_camo
a multimeter would tell you how many volts it is getting.
hearing the motor activate is a decent indicator some voltage is getting there.
it may be engaging the front output and the range indicator is either shot or out of wack. check the connector the best you can assuming you do not have a multimeter
honestly not a whole lot you can do besides fiddle with both connections with a multimeter and a means to check your PIDs with a program like Forscan. the system is a tad more complicated then people realize. you can swap in 4 good relays but those are rarely the problem. usually the wires, connectors or a bad motor.
Old Jan 13, 2020 | 06:34 PM
Lockholder's Avatar
Lockholder
so if it’s not getting enough volts it could be switching but not actually supplying power to it? Cause the motor was new and the Driverside connector is new. I have the passenger side connected just haven’t replaced it yet. So my front shaft spins no matter what and the light for 4wd indicates in on. But just no power.
Old Jan 14, 2020 | 12:24 AM
pirate4x4_camo
you hear the motor, dash light indicates 4x and the drive shaft spins.
sounds like it is in 4wd but your hubs are not engaging.
Old Jan 14, 2020 | 12:26 AM
Lockholder's Avatar
Lockholder
motor makes noise, dash light on, drive shaft only spins when moving. Doesn’t spin when was on jack stands.
Old Jan 14, 2020 | 01:23 AM
Zip's Avatar
Zip
The large snap ring on the rear of the hub has probably come off.
https://www.google.com/search?q=warn...gAlA7M3ay5yGM:
I couldn't find a good picture to show what I mean so this is it. The picture on the right side shows two pieces of the hub. Of those two pieces the one on the left has a smaller snap ring on the middle and a larger one on the outside. The one on the outside is the one that may have come off.
Old Jan 14, 2020 | 07:17 AM
SkySkiJason's Avatar
SkySkiJason
You need a pro scan tool to ID problems with ESOF. If it’s not shifting the t-case - there will usually be DTC’s.
There is a lot more going on than just 12v to the motor....
But, the motor making noise means a lot of that is working! Could be just a bad shift motor. Do not try to operate motor by supplying 12v or with motor off the t-case. Damage to shift motor is likely.
Old Jan 14, 2020 | 07:19 AM
SkySkiJason
Assuming when your hubs are locked the axle shafts and drive shafts are all spinning........
Old Jan 14, 2020 | 10:21 AM
pirate4x4_camo
bench testing the motor doesnt hurt anything. just dont hold voltage to the motor after it reaches its end of range.
and I agree with could be a bad motor even if you hear it. there is more the just the motor to go bad. if the range indicator inside the motor ( the thing the other wires plugs into ). is out of wack or bad, then the motor doesnt know if it is actually in the correct position but will illuminate the dash light anyhow.
and yes forscan not only give you the DTCs but you can run the PIDs and see if the system is functioning correctly.
Old Jan 14, 2020 | 12:36 PM
Lockholder's Avatar
Lockholder
snap rings are good. Checked before replacing both hub assemblies
Old Jan 14, 2020 | 12:37 PM
Lockholder's Avatar
Lockholder
i have no codes or dtcs for it and shift motor is new only few months old. Driverside connector has been replaced (wires correctly) passenger side usually is wet so I’m replacing it
Old Jan 14, 2020 | 12:38 PM
Lockholder's Avatar
Lockholder
hubs locked or not locked front shaft spins occasionally. But if I lock the hubs yes the shaft spins
Old Jan 14, 2020 | 01:17 PM
SkySkiJason
What are you using to pull codes?
