Sponsored by: Real Truck
need help with EEC-iv
Old Jan 17, 2020 | 05:12 PM
Timothy Borg's Avatar
Timothy Borg
Originally Posted by Timothy Borg
yes exactly!I had made a couple minor adjustments, truck was running well. I was simply looking at the timing mark with the light when it just died !No fire since then. And as I said earlier I have replaced the distributor since then ?
also I’ve gone back to check my voltage at TFI, and other than start signal ( which I’ve NEVER gotten ) I look good. So I have replaced the TFI for a second time as well
Old Jan 17, 2020 | 08:49 PM
the_old_ranger's Avatar
the_old_ranger
Well if it didn't throw the timing chain then just be sure you got it itimed right. Did you get the new distributor in the exact same spot?
Old Jan 17, 2020 | 09:37 PM
WWR's Avatar
WWR
Well he's saying he's not getting spark at all. He also says the dizzy is dizzy so the timing chain's intact and it should be sparking, regardless of dist position.
Just curious OP, is this MAF? OBD-II?
Anyway, I'm no further help. But PLEASE post up the resolution, don't leave us hanging. I, at least, will likely learn something
Old Jan 17, 2020 | 09:40 PM
WWR's Avatar
WWR
Also, do you have a tach, and if so does it move when cranking? SHOULD it move when cranking (I honestly don't know)?
Old Jan 18, 2020 | 09:34 AM
Timothy Borg
OBD-1 and Ive tried to get codes using a method I found here at FTE, but that didn't show me anything. And yes im not giving up here , so I will post what I find when I find it.Im sure its going to be the last place I look !!
Old Jan 18, 2020 | 09:36 AM
Timothy Borg
nope, no tach. Good thought though
Old Jan 18, 2020 | 11:07 AM
ashleyroachclip's Avatar
ashleyroachclip
Do you have a cel that comes on with the key in the on position ?
if yes , does it go out when you are cranking the engine ?
Old Jan 18, 2020 | 11:37 AM
the_old_ranger
At this point I think the easiest thing for you to do is turn to YouTube or better yet a service manual and see how to jumper the diagnostic connector and see if it throws a code. I don't know how it could have lost spark at the same time you were checking the timing.
Old Jan 18, 2020 | 03:50 PM
WWR's Avatar
WWR
OP I bet you've already done this but maybe CAREFULLY check the connector between dist & remote mount TFI?
I mean returning to KISS the truck died while you were moving the distributor (albeit small movements I know).....
Old Jan 19, 2020 | 12:18 PM
JoePa2's Avatar
JoePa2
Answering you question concerning grounding the coil - yes you can generate a spark that way - you measured 12 volts at the battery side of the coil - as you should - you measured 12 volts at the ground side of the coil - as you should if no ground is there - take a wire and connect it to the negative side of the battery and the ground side of the coil - current will flow through the primary winding of the coil thus establishing a magnetic field - now unhook this wire from the battery - the magnetic field will collapse thereby causing a high voltage in the secondary winding of the coil and generating a spark - keep doing this to the rest of the high voltage circuit all the way to a spark plug - this way you will know if the high voltage circuit is ok - if so then you have a grounding problem
rodp14
54
Jul 9, 2017 08:13 PM
Eians86f150
Electrical Systems/Wiring
Aug 14, 2013 09:15 AM
lars of colorado
Dec 8, 2010 09:48 AM
ksubigbuck
May 14, 2008 10:05 PM
sprocketford
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 20, 2008 02:25 PM
