Injector Issue
Old Jan 12, 2020 | 09:59 PM
bruno2's Avatar
bruno2
Injector Issue
So I am getting a code for # 5 & 7 being out of range. The VC gasket was smashed and burned on that bank . I replaed the gasket, uvch and pigtail. I peeled the wire harness back and inspected it all the way back to the bulkhead. I ohmed those injectors and they ohmed at 3.4 and 3.5. I am still getting the same code. Both a buzz test and cct give me the same code.
Old Jan 13, 2020 | 07:45 AM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...load-test.html
Ohm out harness at IDM with pic in link
Old Jan 13, 2020 | 07:46 AM
97-psd's Avatar
97-psd
You can swap the injectors around and see if the issue follows the injector. If it does you have an injector problem. If it stays will the cylinder then you still have a wiring problem
Old Jan 14, 2020 | 06:33 AM
bruno2's Avatar
bruno2
Knottyrope, according to the pic you linked to I need to put my test leads on the two pin positions mentioned for #5 & #7 to read resistance? That was what I got from the pic.
Old Jan 14, 2020 | 08:40 AM
knottyrope's Avatar
knottyrope
ohm out the whole connector with that chart, not just 5 and 7
Its easy to mix one wire on a repair and have IDM shut down
elyrain
Jan 10, 2015 05:40 PM
Z-MAN
Dec 27, 2014 12:07 PM
Jay Fletcher
Apr 7, 2013 10:33 AM
Aki_A
Mar 22, 2011 05:33 AM
RRranch
13
Nov 27, 2009 10:49 AM
