Tires and Wheels
Old Jan 12, 2020 | 11:19 AM
money pit 69's Avatar
money pit 69
Tires and Wheels
Hello I have a 1987 Ford F-250 4x4. My wheels and tires are trash. So I saw a set for sale off of a 1997 Ford 4x4. Question is will they fit my truck. Thx David
Old Jan 12, 2020 | 11:47 AM
sandymane's Avatar
sandymane
Specs are the same. Sandy
Old Jan 12, 2020 | 11:56 AM
rla2005's Avatar
rla2005
If the 1997 4x4 is a light duty F250 they will not fit....that model shares the newer body style as the jelly bean F150 (10th Gen) with metric wheel specifications.
Old Jan 12, 2020 | 12:01 PM
sandymane's Avatar
sandymane
What about them won't fit Randy? Thanks Sandy Never mind I now see you were comparing to a 150.
Old Jan 12, 2020 | 12:12 PM
money pit 69
hello sandymane thx for the info. Where can I fine the spec's. Do I just measure the center hole and the center to center of the lug holes?
Old Jan 12, 2020 | 12:23 PM
sandymane's Avatar
sandymane
https://www.wheel-size.com/size/ford/f-150/1997/ If you put in both years it show all specs. I think this is the site I used for you. Sandy
Old Jan 12, 2020 | 02:36 PM
Nothing Special's Avatar
Nothing Special
Not an F-150, a '97 F-250. It has 7 lug wheels on a metric bolt pattern. Nothing about them will fit the older trucks.
However, '97 F-250HDs still share the old body style and the 8 on 6.5" bolt pattern. Those will fit an '87 F-250 or F-250HD.
For what it's worth, Ford never made anything they called a "light duty" F-250. They made an F-250 and an F-250HD. Up through '86 they were both badged (and usually called) "F-250". In '97 Ford's "better idea" was to have two completely different F-250s as noted above. At least in '97 they did put "heavy duty" on the tailgate of the F-250 HD.
'98 was slightly better than '97. There was no F-250HD (or F-350). Just the"jelly bean" F-150 and the matching F-250.
Then in '99 Ford straightened it all out by creating a new mess (but a mess that really didn't matter). They started calling the 3/4 ton truck "F-150 7700" (but just badged "F-150"). Meanwhile the F-250HD dropped the "HD" and was called F-250 SuperDuty. Which meant the name "Superduty" could no linger be used for the heavier-than-F-350 F-series. So they changed it to F-450 (and F-550)
Old Jan 12, 2020 | 07:28 PM
Air Cooled Nut's Avatar
Air Cooled Nut
Who's on first? You're right, that is a mess!
Stevekron1
Sep 27, 2015 09:46 AM
rakent
Mar 12, 2004 09:22 AM
