Good morning all, I have an opportunity to get an 08 SD with a hole in the block, and a 5.4 engine from a totaled 04 SD. what kind of issues could i run into doing this swap, Both are automatics, will the 04 v8 bolt up to the 08 tranny? or will i need to swap tranny as wel, motor harness, ECM?? lots of unknowns for me. was the hole in the block a common issue on the V10? is it worth fixing the hole or swapping the block. any input would be great.
cool, thanks for the info.
my buddy who owns the 08 said the hole in the block was common on the 6.8 but i havent found any info regarding this. have you seen this before?
First I've heard of it. It isn't common, by my knowledge.
