Won't Start
Old Oct 12, 2003 | 07:07 PM
Simi Jim's Avatar
Simi Jim
Angry Won't Start
Help!!
1997 F250 PSD, ran fine on Monday. Went to start it today, it will crank fine, but won't start. The wait to start light never comes on (of course it is 80 deg) When I tried to retrieve the error codes, it will not sync up. All fuses check fine and I swapped the relays around. I am guessing PCM at this point, any one have a better idea.
Thanks for any help
Jim
Old Oct 13, 2003 | 07:13 AM
powerstroker250's Avatar
powerstroker250
PSD's are very sensitive to battery voltage. My coworker went to start his truck, it would crank but would not fire and no smoke. Jumped it and it started. Started when warmed up too. Replaced the batteries and no more problems.
Old Oct 15, 2003 | 01:37 AM
sfsterling's Avatar
sfsterling
Check the diode in the fuse box (it is white). If the diode is bad it will not start as the diode controls power to some of the relays.
Old Oct 15, 2003 | 03:04 PM
Jerrybo66's Avatar
Jerrybo66
I vote with Powerstroker...........Been there, done that ..... Charge up the batteries or jump it...It will start again until you let it sit long enough for the battery to short down.. Probably only one is bad but change them both .. Good luck .......
Old Oct 15, 2003 | 03:52 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I agree with Jerrybo66 and powerstroker 250. When the batteries on my X were dying, I had them both tested and one came out good and the other bad. I replaced the both of them under warranty and I haven't had a problem since. So, just get some new batteries and you, as well as your rig, should be just fine.
Old Oct 18, 2003 | 06:49 PM
Simi Jim's Avatar
Simi Jim
Smile
Well it turned out to be the PCM. Changed it out yesterday, and everything is good now.
Hope this helps someone else out.
Jim
Old Oct 18, 2003 | 09:58 PM
cmrclgc's Avatar
cmrclgc
Cool NO START CRANK ONLY....
HAD THE SAME ISSSUEABOUT A MONTH AGO TURNED OUT IT WAS THE KAM SENSOR........AT THE FRONT OF THE MOTOR JUST ABOVE THE HARMONIC BALANCER PASSENGER SIDE.....F Y I
Old Oct 19, 2003 | 03:22 PM
1Upracing's Avatar
1Upracing
Thumbs up
never mind
my94red4x4
Mar 24, 2013 01:41 PM
hotroddsl
60
Sep 5, 2011 06:08 PM
Jims 08 stroker
6.4L Power Stroke Diesel
Aug 4, 2011 09:07 AM
Jim Hughes
18
Jul 27, 2009 02:14 PM
JimR1957
Oct 6, 2006 10:42 PM
