trans filter and fluid
Old Oct 19, 2003 | 10:49 AM
F0rdF0rever's Avatar
F0rdF0rever
Im planning on changing my trans fluid and filter today. Does anyone know how many quarts go into a 95 350 4x4 psd? And whats everyone using?
Old Oct 19, 2003 | 04:40 PM
HeatStroked's Avatar
HeatStroked
I've read on several threads that the either the Amsoil or Schneider synthetic oils are the way to go.
Not sure about the filter.
Old Oct 19, 2003 | 05:43 PM
F0rdF0rever
Thanks heatstroked. I read somewhere it will take 5 quarts. Do you know where the drain is. Im guessing its on the trans pan.
Old Oct 19, 2003 | 06:00 PM
philn's Avatar
philn
Not sure if your is comparable to my '02, but the pan has a drain plug. Total change is much more than 5 quarts if you are planning to flush and refill the entire transmission circuit. IMO that's the only way to go. I just did my '02 and it took about 15 quarts to flush and refill. Used synthetic as well. IMO Syn. is the only was to go in transmissions.
