I fabbed up a cross bar up under the dash (saw the idea here, somewhere) and the fuse panel is mounted to a plate, mounted to the crossbar... It also gives you nice place to support wire runs and other accessories.
Since I don't get the opportunity to say this very often I'm going to take advantage . MINES BIGGER THAN YOURS IS . The size of it will leave it protruding quite a bit from the kick panel and leave no room for my intended speaker , up under the dash similar to jniolon's would be an option but not user friendly . Under the seat would be more user friendly but allot of extra wire and routing . For those that have put them under the seat , did you run the wires inside or go though the floor under the cab ?
Because I have bucket seats and a console I ran them inside the console, the drawer looks cool (?) but you are right, it was way to much work and most of the circuits have to be doubled, much wire as you can see.
(I have never showed this picture before, too embarrassed.)
