need advice
Old Jan 8, 2020 | 07:35 PM
saauvenshine's Avatar
saauvenshine
need advice
Finally got my 54 running better today. It has a 239 y-block and a pertronix coil and module instead of points. I had it running good and since the engine has been sitting awhile i poured some seafoam through carb and let set for an hour or so. When i went to start it back up it would not start even with gas poured down carb it wouldn't even act like it would. I check coil and it was firing good and spark plug wires where also firing good and fuel pump was good. What are some other things that i could check as i am getting fuel and spark but engine is not even attempting to start. I would not think pouring seafoam in carb would cause it not to start back up and if i am pouring gas down carb why would it not attempt to start. Thanks
Old Jan 8, 2020 | 07:39 PM
pintoplumber's Avatar
pintoplumber
Did you leave the key turned in the on position for a period of time? I believe that’s what ruined my pertronix.
Dennis
Old Jan 8, 2020 | 07:47 PM
bigwin56f100's Avatar
bigwin56f100
Too much gas/sea foam probably flooded
Old Jan 8, 2020 | 08:59 PM
Tedster9's Avatar
Tedster9
Try removing the spark plugs and turning it over with the starter for several seconds, maybe let it set a while or overnight. Check for good spark at a grounded plug, re-install plugs etc. Vroom! Go for a beer.
Old Jan 8, 2020 | 09:43 PM
saauvenshine
Dennis if pertronix was bad would i still be getting fire at the coil and plugs? Thanks
Old Jan 8, 2020 | 09:54 PM
Tedster9's Avatar
Tedster9
No. The Ignitor either works, or it doesn't, if Pertronix can believed. They have a website, and a Techline, both are real good.
Old Jan 8, 2020 | 10:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Agree with this. Pull the plugs, you'll know immediately if that's the case.
Old Jan 13, 2020 | 04:46 PM
petemcl's Avatar
petemcl
Try ether instead of gas down the carb to dry things out.
Old Jan 14, 2020 | 02:21 PM
Matt Js 54's Avatar
Matt Js 54
If you have fuel, spark, and compression, that's all you need, as long as timing is still okay. If it was running well before you poured the Seafoam into it, and nothing else changed, that's probably all it was, just flooded.
tmeric7
Apr 22, 2020 09:50 AM
Dane916
Feb 21, 2017 07:33 PM
MHull
43
Mar 18, 2006 08:20 PM
nick65f100
Aug 22, 2005 11:42 PM
bluestang65
Apr 25, 2004 07:39 PM
