240 No Go
Old Feb 13, 2003 | 08:09 PM
bluestang65's Avatar
bluestang65
240 No Go
I can crank my 1966 240 cid all day long and no start. pulled number one plug out and saw a spark when i grounded it and cranked the engine, so i assume spark is ok. Timing should be good as the truck was running when parked. The points, condenser, wires, rotor, cap and plugs were all replaced and the truck was running after they were done. Now, after sitting, the old motor doesnt want to start. It has a clear fuel filter and fuel is going up to the carb. I even tried starting fluid, but the old thing wouldnt give in. My wife would love to see this six-banger run so we dont have to go with a 460. Anyone have any ideas?
Old Feb 14, 2003 | 01:32 PM
knocturnal's Avatar
knocturnal
240 No Go
umm... are your floats full?? all wires connected??? it should fire with starting fluid and thats sayin im not gettin spark to go boom. so check your ignition system...oh yea to fill the floats or my way to do it is dump some gas down the carb..
Old Feb 14, 2003 | 10:32 PM
idealtrucks's Avatar
idealtrucks
240 No Go
try cranking it some and then pulling ga plug and seeing if its wet and gettin gas. if its dry theres a problem in the carb
Old Apr 25, 2004 | 07:39 PM
creep2shift's Avatar
creep2shift
what color is your spark? My old '67 won't start with orange spark, it has to be blue. Is your coil or resistor bad?
