89 f150 speedometer cable
Old Feb 9, 2001 | 05:17 PM
mtucker's Avatar
mtucker
Old Mar 7, 2001 | 05:20 PM
mike a's Avatar
mike a
CABLE IS TICKING AT LOW SPEED,TOOK CABLE OFF AT TRANSMISSION TRIED TO PULL OUT BUT FEELS LIKE WILL NOT RELEASE.DO I NEED TO PULL OFF INST. PANEL? IF SO ,MUCH OF A JOB? TRUCK IS AUTO,WITH CRUSE IF IT MATTERS. THANKS IN ADVANCE. MIKE
Old Mar 7, 2001 | 07:37 PM
jakegypsum's Avatar
jakegypsum
If you hear the ticking sound from the cab, it is a good chance that the cable that comes from the cruise control to the speedo is where the problem is. It sounds like all you need to do is pull the cable out and lube it with a lubriplate type of grease. good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old Mar 7, 2001 | 08:52 PM
nitro94's Avatar
nitro94
I sure that you will need to remove the inst. cluster to release the speedo cable from the head. Pull cable out, lube and reinstall.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
