So i have a 2012 f250 super duty xlt 4x4 crew cab with the 6.2l gas with 3.73 differential... I am currently using this to pull my 5th wheel camper dry weight is 8650 lbs and gross I'm thinking is about 10,000-10,500 lbs... I'm looking at getting a different 5th wheel camper and was wondering if anyone is pulling with this model truck and what kind of weight I could pull without alot of wear and tear on truck...the campers I'm looking at would be a dry weight of 10,000 or a little over and gross would be 12,000 to 12,500 lbs...also I'm only using this on the weekends and traveling at most 2 to 4 hours one way
Keep in mind that most RV manufacturers rarely have the actual weight of the RV on the sticker and the majority of the time the weights are considerably lighter. So keep that in mind when looking at heavier RV’s. The other considerations are your payload vs pin weight of the 5er. Payload can be eaten up very quickly...
Yes thank you...have you pulled with a gas 3/4 ton if so how big was the camper
Hey Chad, I pull with a F350 Dually, when I bought the truck it was going to be a tow pig period. As I mentioned above the payload capacity in a 3/4 ton can be consumed fairly quickly. Look at what your payload capacity currently is rated at. Now what is your camper’s current weight loaded, what is your pin weight? Do you have any payload capacity left? The way people drive today you don’t wanna be pushing the limits of your truck...
