camper weight help
Old Feb 7, 2012 | 08:43 PM
Nickel-n-Dimer's Avatar
Nickel-n-Dimer
camper weight help
I have a 1997 f350 drw and i'm thinking about buying a 2001 arctic fox 1150, if anyone can help is this to much camper for my truck?? Thanks so much!
Old Feb 7, 2012 | 08:45 PM
White 97 xlt's Avatar
White 97 xlt
Have you got any details on the camper? Like total weight and such....
Old Feb 7, 2012 | 09:21 PM
kd0axs's Avatar
kd0axs
Wow, that's a huge camper. Dry weight is just shy of 4,000 lbs and wet weight is just over 5,000 lbs.
Not sure what payload capacity is on a 97 DRW, but to find out for sure you need to weigh your truck and then subtract the weight from the truck's GVWR. Also keep in mind that you need to add the weight of passengers and other cargo in addition to the camper's weight.
Just my opinion, but if I was looking for something that big I would be looking at a travel trailer rather than a slide in camper.
Old Feb 7, 2012 | 09:35 PM
Midnite1987's Avatar
Midnite1987
found this, according to this my 95 f150 max is 7100lbs and the f350 drw is 10,000lbs
Old Feb 7, 2012 | 09:41 PM
Midnite1987
my bad, just googled it an realized that its an in box camper not trailer....
found this tho, but also have to gear, people, fuel, food and whatever else will be in the truck into that aswell. looks like you would need a F-SUPERDUTY if you wanted to stay in the 87-97 bodystyles of find a different camper
The two-wheel drive dual-wheel base crew-cab XL with a 5.8-liter engine has a payload of 4,621 lbs., a towing capacity of 7,401 lbs. and has a curb weight of 5,379 lbs.
The two-wheel drive standard cab XL with a single wheelbase and a 5.8-liter engine has a payload of 3,896 lbs., a towing capacity of 7,101 lbs. and has a curb weight of 5,105 lbs.
The four-wheel drive crew-cab XLT with a single wheelbase and a 5.8-liter engine has a payload of 3,565 lbs., a towing capacity of 7,101 lbs. and a curb weight of 5,658 lbs.
The dual-wheel base extended cab, two-wheel drive XLT, with the 7.3-liter engine has a payload of 4,656 lbs., a towing capacity of 10,000 lbs. and a curb weight of 5,343 lbs.
would even be iffy with a 2010 f350
Old Feb 7, 2012 | 11:16 PM
cj06's Avatar
cj06
Anyone with Arctic Fox 811 on 3/4-ton? - Dodge Diesel - Diesel Truck Resource Forums
I just bought a 2001 Arctic Fox 1150. I haul it with a 96 duelly. The dry weight posted in the literature is a little misleading. you have to add all the options as well. Our capacities are very similar, except for black water, which is not a factor, because you do not travel with black water anyway.
When i weighed my truck/camper combination, no fluids, no cargo, only a full tank of fuel, i weighed 12000 lbs. Granted, my camper is loaded, nearly every option available. The trucks GVWR is 11000 lbs. I am a 1000 lbs. over weight, with no cargo, or fluids!
The truck seems to handle the weight OK, enough brakes and power, and i did have to install air bags which i inflate to nearly 100 lbs.
The previous owner had a 1 ton SRW, but had to sell the camper because he kept blowing out rear tires on the truck.
I would suggest you carefully determine your actual,( going down the road ),weight.........As a side note; the Arctic Fox, is a beautiful camper!!
Old Feb 8, 2012 | 07:16 PM
Nickel-n-Dimer
thanks everyone for the help, it really helps!
Old Feb 8, 2012 | 08:39 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I use to have an old full size 12ft. 1977 Shamrock Slide in camper in my stock Single wheel F250.
On the scales, truck & camper was just over 5 tons, but it took it fine with the help of timbren springs (empty rubber boot).
You have nothing to worry about with a Dually F350! It will be alot more stable, especially on windy days. On windy days me, the truck would sway side to side pretty bad, being only single wheel, and no sway bars.
MsLola
26
Jun 22, 2024 08:57 AM
sncbluegt
6.7L Power Stroke Diesel
30
Nov 20, 2010 12:16 AM
anothersteveg
Aug 11, 2007 09:13 AM
Fordtruck350
Dec 26, 2004 10:30 PM
Fordtruck350
Dec 23, 2004 01:16 AM
