LAZY TAKE OFF
Old Jan 7, 2020 | 03:29 PM
Paul Miles's Avatar
Paul Miles
LAZY TAKE OFF
My 94 F150 died on me , I replaced the PCM and the ICM ended up replacing the distributor to get it running . Will crank and run good but is lazy on take off . Anyone have any suggestions?
Old Jan 7, 2020 | 03:48 PM
88n94's Avatar
88n94
Did you set the timing to ten degrees before top dead center with the spout connector removed?
Old Jan 7, 2020 | 05:09 PM
Paul Miles's Avatar
Paul Miles
It is a new computer had not been ran on it . does it still make a difference?
Old Jan 7, 2020 | 05:10 PM
torq'ta 5 8's Avatar
torq'ta 5 8
what motor, trans, check for codes, which ICM did you get, grey or black,
Old Jan 7, 2020 | 05:16 PM
Milpool's Avatar
Milpool
If you replaced the distributor, you should reset the timing.
Old Jan 7, 2020 | 06:10 PM
timbersteel's Avatar
timbersteel
What color ICM did you replace with? Your truck should have had a Black ICM. Using a Grey ICM will give you issues.
Old Jan 8, 2020 | 07:23 AM
rla2005's Avatar
rla2005
https://www.ford-trucks.com/forums/1609112-94-f150.html
Old Jan 8, 2020 | 10:03 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Old Jan 8, 2020 | 02:14 PM
joey2fords's Avatar
joey2fords
you have some very knowledgeable people chiming in; you can make it easier for them to help you by keeping it all in one thread. good luck.
Armyrules2
22
Oct 28, 2019 12:33 PM
im2tall33
Dec 11, 2014 09:46 AM
JimiLL
Feb 19, 2014 01:08 PM
97rangerguy
Apr 29, 2005 03:33 PM
87BigBronco
Sep 10, 2004 09:07 AM
