E-350 Glow Plugs
Old Jan 7, 2020 | 12:16 AM
Stayoutdoors's Avatar
Stayoutdoors
E-350 Glow Plugs
Hey guys,
My 2003 E-350 (7.3 L) is getting harder to start everyday. Luckily, it's only on the first start of the day, but I think it may be time to replace the glow plugs. Does anyone know if it's possible to do it without lifting the body off the chassis? Going to test the resistance of the plugs tomorrow with a multi-meter. Any other suggestions/recommendations on other stuff I should check while I'm at it?
Thanks
Old Jan 7, 2020 | 02:15 PM
Cubey's Avatar
Cubey
Trailering
You might have better luck asking at OilBurners, where there's all diesel owners: https://www.oilburners.net/categorie...sel-forums.10/
I have a diesel but it's an 85, back when you can still each things.
Old Jan 8, 2020 | 04:46 PM
FinnishStroker's Avatar
FinnishStroker
You can change glow plugs without lifting a body.
Those valve cover bolts are tricky,some bolts is best to open from the wheel well.
Pulling the turbo makes more room.
You may consider new VC gaskets and UVCH wiring..
Possible things to do while youre there:
Upgrade to bellowed up pipes.
If you dont need EBPV,do blank pedestal and exhaust flapper delete.
AIH delete also possible.
Check for play in turbo shaft,look If the compressor wheel is dusted and rebuild If needed.
Check condition of glow plug relay,better upgrades are available.
Add fuel pressure sender to fuel bowl.....
kent hittle
16
Feb 11, 2016 04:18 PM
GHeTTo JOe
6.4L Power Stroke Diesel
Mar 14, 2013 09:06 AM
mech1
Feb 10, 2012 05:11 AM
GHeTTo JOe
Nov 18, 2008 01:25 AM
Banshee Ben
13
Jun 7, 2005 02:19 PM
