I have recently developed a coolant leak. I am not sure where the leak is exactly but it is coming from the front center part of the engine. The engine runs just fine and the only problem I have had is no heat. Before I take it to a mechanic I was wondering if using Radiator Stop Leak will fix the problem.
No! You are way better off finding out where the leak is coming from.
Don't use stop leak. Its probably the o ring in the hose connection. Should be a easy diagnosis. Even a water pump is a easy job on a 6.2.
